walksabout
#1 Posted : Saturday, October 21, 2017 3:36:18 PM(UTC)
walksabout
I have a Panasonic AW-UE70 with that's using a username and password. It's streaming correctly, but I haven't been able to get the PTZ controls to connect. The URL I'm using is the obvious one, http://uname:pword@ipaddress, and it works when the camera doesn't require authentication, but no luck when it does. Does anyone have any other ideas?
sinc747
#2 Posted : Monday, October 23, 2017 10:15:37 AM(UTC)
sinc747
You want to control the cam using vMix? Have you tried entering the IP address on the PTZ tab for that Input?
- Tom
walksabout
#3 Posted : Tuesday, October 24, 2017 10:33:52 AM(UTC)
walksabout
Thanks, Tom. I have tried that - vMix connects and controls the camera when the camera has no password set, so I know it can do it. Once the camera has a password set, vMix fails to connect, even when I update the connect string to use the format http://uname:pword@ipaddress . Can you think of anything else?
seb666
#4 Posted : Wednesday, October 25, 2017 9:03:53 AM(UTC)
seb666
You don't need a password for PTZ controls. I've got the same camera, just enter the IP address under PTZ and choose Panasonic protocol.
walksabout
#5 Posted : Wednesday, October 25, 2017 10:24:34 AM(UTC)
walksabout
Thanks for the reply, Seb.
It's true that I can use the camera without a password set, but the camera is for public events on a college campus, so I have to set one. When there is password set, though, the PTZ controls in vMix fail to connect. Are you seeing different behavior?
Ronald555
#6 Posted : Saturday, October 12, 2019 6:36:48 AM(UTC)
Ronald555
I've got the same issue with my Sony SNC-ZP550.
This camera is connected to the internet, so I have to use Viewer authentication for safety reasons, but then the camera cannot connect.
Is there a solution for this?
I already changed the portnumber of the camera to a non standard number, but because I need remotely acces to my camera's they are portforwarded in my router.
I can measure an increase of network traffic when authentication is turned off.
It's clearly not save to disable this safety feature, there are unfortunately a lot of bots busy on the internet.
Ronald555
#7 Posted : Tuesday, October 15, 2019 4:29:34 AM(UTC)
Ronald555
Nobody?
Martin, should a different username/password format be used or has the security in these been overlooked?
