I have a Panasonic AW-UE70 with that's using a username and password. It's streaming correctly, but I haven't been able to get the PTZ controls to connect. The URL I'm using is the obvious one, http://uname:pword@ipaddress, and it works when the camera doesn't require authentication, but no luck when it does. Does anyone have any other ideas?
Joined: 8/2/2013(UTC) Posts: 1,094   Location: Fairhope, Alabama USA Thanks: 578 times Was thanked: 202 time(s) in 168 post(s)
You want to control the cam using vMix? Have you tried entering the IP address on the PTZ tab for that Input?
- Tom
Thanks, Tom. I have tried that - vMix connects and controls the camera when the camera has no password set, so I know it can do it. Once the camera has a password set, vMix fails to connect, even when I update the connect string to use the format http://uname:pword@ipaddress . Can you think of anything else?
Joined: 12/10/2016(UTC) Posts: 126  Location: Frankfurt, Germany Thanks: 93 times Was thanked: 19 time(s) in 14 post(s)
walksabout wrote:I have a Panasonic AW-UE70 with that's using a username and password. It's streaming correctly, but I haven't been able to get the PTZ controls to connect. The URL I'm using is the obvious one, http://uname:pword@ipaddress, and it works when the camera doesn't require authentication, but no luck when it does. Does anyone have any other ideas? You don't need a password for PTZ controls. I've got the same camera, just enter the IP address under PTZ and choose Panasonic protocol.
Thanks for the reply, Seb.
It's true that I can use the camera without a password set, but the camera is for public events on a college campus, so I have to set one. When there is password set, though, the PTZ controls in vMix fail to connect. Are you seeing different behavior?
Thanks: 28 times Was thanked: 3 time(s) in 3 post(s)
I've got the same issue with my Sony SNC-ZP550.
This camera is connected to the internet, so I have to use Viewer authentication for safety reasons, but then the camera cannot connect.
Is there a solution for this?
I already changed the portnumber of the camera to a non standard number, but because I need remotely acces to my camera's they are portforwarded in my router.
I can measure an increase of network traffic when authentication is turned off.
It's clearly not save to disable this safety feature, there are unfortunately a lot of bots busy on the internet.
Nobody?
Martin, should a different username/password format be used or has the security in these been overlooked?
