Joined: 10/24/2017(UTC) Posts: 1 Location: Toronto, Ontario
Hello All,
Hopefully I will be able to get the help needed here. I am trying to take separate audio through NDI and am wondering if it is at all possible.
For 1 laptop I have a Behringer U-Phoria UMC404HD audio interface plugged in, and am running 4 sennheiser ew100s
On the 2nd laptop I am running vmix as the master and would like to take all 4 microphones as separate audio from the 1st computer so I can mix all differently.
I really hope someone can help me resolve this issue I am having. Thanks and have a great one.
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 152 times Was thanked: 76 time(s) in 57 post(s)
You will have to turn on NDI Audio outputs. And then you will have 3 stereo pairs coming out of vMix.
Master, A and B.
Hopefully that is what you need, if not take a look at Dante VIA.
Steve
Rank:: Advanced Member
oneilvmix2 wrote:For 1 laptop I have a Behringer U-Phoria UMC404HD audio interface plugged in, and am running 4 sennheiser ew100s I guess what you're really looking for is an app which takes ASIO audio sources and transmits them over NDI (as four NDI streams, or one 4-channel NDI stream?), in order to pick up the four individual channels from the UMC404HD. However, I don't think such an application exists in standalone form. A copy of vMix can more or less do it, certainly if you don't mind the four sources being encoded as two L/R stereo pairs using the A & B bus NDI outputs, along with the appropriate internal audio routing.
zenvideo wrote:oneilvmix2 wrote:However, I don't think such an application exists in standalone form. https://www.reaper.fm/:-)
I am aware of Reaper but don't use it (yet), and it's a while since I looked at it. When did they start supporting NDI, and what form does that support take?
zenvideo wrote:I am aware of Reaper but don't use it (yet), and it's a while since I looked at it. When did they start supporting NDI, and what form does that support take? Sorry, not much information, but it is a piece in conjunction with Dante ASIO audio. We use all of this in our production systems with vMix. What he really needs is Dante, not NDI. Steve
