oneilvmix2
#1 Posted : Tuesday, October 24, 2017 3:41:36 PM(UTC)
oneilvmix2
Hello All,
Hopefully I will be able to get the help needed here. I am trying to take separate audio through NDI and am wondering if it is at all possible.
For 1 laptop I have a Behringer U-Phoria UMC404HD audio interface plugged in, and am running 4 sennheiser ew100s
On the 2nd laptop I am running vmix as the master and would like to take all 4 microphones as separate audio from the 1st computer
so I can mix all differently.
I really hope someone can help me resolve this issue I am having. Thanks and have a great one.
stevespaw
#2 Posted : Tuesday, October 24, 2017 4:32:30 PM(UTC)
stevespaw
Was thanked: 76 time(s) in 57 post(s)
You will have to turn on NDI Audio outputs.
And then you will have 3 stereo pairs coming out of vMix.
Master, A and B.
Hopefully that is what you need, if not take a look at Dante VIA.
Steve
zenvideo
#3 Posted : Tuesday, October 24, 2017 6:34:34 PM(UTC)
zenvideo
I guess what you're really looking for is an app which takes ASIO audio sources and transmits them over NDI (as four NDI streams, or one 4-channel NDI stream?), in order to pick up the four individual channels from the UMC404HD. However, I don't think such an application exists in standalone form. A copy of vMix can more or less do it, certainly if you don't mind the four sources being encoded as two L/R stereo pairs using the A & B bus NDI outputs, along with the appropriate internal audio routing.
stevespaw
#4 Posted : Tuesday, October 24, 2017 9:32:04 PM(UTC)
stevespaw
zenvideo wrote:
https://www.reaper.fm/
zenvideo
#5 Posted : Wednesday, October 25, 2017 8:57:21 AM(UTC)
zenvideo
I am aware of Reaper but don't use it (yet), and it's a while since I looked at it. When did they start supporting NDI, and what form does that support take?
stevespaw
#6 Posted : Wednesday, October 25, 2017 9:24:48 AM(UTC)
stevespaw
Sorry, not much information, but it is a piece in conjunction with Dante ASIO audio. We use all of this in our production systems with vMix.
What he really needs is Dante, not NDI.
Steve
Similar Topics
NDI Audio Capture only (NDI)
by waxxel 1/14/2026 6:16:25 AM(UTC)
Random NDI audio dropouts (NDI)
by ProducerAnywhere 8/31/2024 5:29:35 AM(UTC)
NDI Audio output sample rate different from vMix master sample rate (NDI)
by Maestro232 8/7/2023 1:07:39 AM(UTC)
NDI Audio Signal Jitter (NDI)
by tdhfox21 7/24/2023 12:15:19 PM(UTC)
Seperate NDI audio inputs in from MS TEAMS (NDI)
by MSFTGuruGuy 4/1/2022 5:58:08 AM(UTC)
NDI Audio Help (General Discussion)
by jvphobic 3/10/2022 4:01:12 AM(UTC)
NDI Audio Direct - vMix doesn't find VST3 (NDI)
by tbarden 8/23/2021 11:19:27 PM(UTC)
NDi audio out (NDI)
by sepr 2/22/2021 8:56:20 PM(UTC)
NDI Audio From Teams to vmix issue (NDI)
by kevhilge 1/27/2021 4:11:51 AM(UTC)
vmix with teams error NDI audio (NDI)
by barriod 1/23/2021 2:26:17 AM(UTC)
NDI Audio issues from vMix to Teams (NDI)
by Rickard_Bjorling 1/19/2021 8:21:53 AM(UTC)
Muting sound on laptop also mutes NDI audio feed on some laptops... (NDI)
by bluesky 9/8/2020 12:52:48 AM(UTC)
VMix NDI Audio pops and clicks on Zoom (NDI)
by Ezzra 7/17/2020 6:35:14 PM(UTC)
Help. Enabling NDI audio outputs, kills existing buses (General Discussion)
by Indrestudios 6/2/2020 1:01:18 AM(UTC)
skype line(newtek NDi Audio) (NDI)
by Ketan Patel 4/6/2020 9:17:38 PM(UTC)
NDI audio latency (NDI)
by Scott Barnett 4/2/2020 12:39:39 AM(UTC)
NDI Audio from vMix to BirdDog (Feature Requests)
by r@wisla 10/1/2018 3:08:56 PM(UTC)
NDI Audio Issue (NDI)
by gruppo2 10/22/2016 10:55:00 AM(UTC)
NDI Audio Only Monitor app? (NDI)
by RoboST 6/25/2016 8:35:08 PM(UTC)
