Cris_AV
#1 Posted : Friday, October 13, 2017 12:54:07 AM(UTC)
Cris_AV
Hi Everyone, first of all say hello to all in this very cooperative forum. Great one!
I've been trying for days to make my decklink duo 2 work full duplex and no luck yet. No problem on getting 2,3 or 4 inputs working but I can't get the card work as output. For what I do (Mostly corporate conferences) I need to configure the card as 2 in 2 out or 3 in 1 out. I have tried every single "Decklink video render" output but nothing. Instead I get the following message:
"The selected external renderer device is in use or does not support the selected format. Please check your external output settings and try again"
Of course I did try different resolutions with every single frame rate and still nothing.
If any of you can help me I will own you one
Thanks!
Cristian
sinc747
#2 Posted : Friday, October 13, 2017 2:31:34 AM(UTC)
sinc747
You'll need to use the Blackmagic Video Utility app to change the port routing, then it should work in vMix. The app was installed when you installed the driver.
- Tom
corporatejames
#3 Posted : Friday, October 13, 2017 6:52:09 AM(UTC)
corporatejames
- Tom
Second what Tom said. I use this card in a external AKiTiO Thunder2 PCIe Box and use in similar way with 4in or 3 in 1 out etc depending on the need. Needs to be configured in the Blackmagic
Desktop Video Setup application.
Cris_AV
#4 Posted : Friday, October 13, 2017 10:09:32 PM(UTC)
Cris_AV
Thanks very much for your reply
I did not mention it but I have done all the configuration on the blackmagic desktop video setup. I can get 2,3 or 4 input but no output.
I set it up as following
decklink 1= 1
decklink 2= 3
decklink 3= 2
decklink 4= None
With this I get the error I typed before on vMix
I know this card works for everyone so I'm conscious that I'm doing something wrong but seriously I have tried so many times that I got lost.
If anyone can send me pics of their configuration on the blackmagic software and the external output window on vmix I would appreciate it.
Thanks in advance
Cristian
Cris_AV
#5 Posted : Tuesday, October 17, 2017 7:17:34 PM(UTC)
Cris_AV
Anyone?
Mathijs
#6 Posted : Monday, October 30, 2017 2:17:17 PM(UTC)
Mathijs
In my config the card is just set with all i/o routed to their own connector.
In vMix I can set them up as input or output.
As long as there is no input set on the same i/o, you can set the output to the card on any connector.
Videoslave
#7 Posted : Thursday, November 16, 2017 7:58:27 AM(UTC)
Videoslave
Did you solve this ? I plan to buy the DeckLink Duo myself but for me it is crucial to get 3 Inputs with one output. Is it audio embeded ?
best
David
Cris_AV
#8 Posted : Thursday, November 16, 2017 6:41:16 PM(UTC)
Cris_AV
Hi David , yes I finally did it today. On the blackmagic desktop video utility set all input to a single connector (1 to 1). Sorry Im not on my vmix machine so I can’t be more specific at the moment. Let me know if you need help.
Cris
emilt
#9 Posted : Tuesday, March 2, 2021 8:01:52 AM(UTC)
emilt
Norway
3 years later... we still need help on this topic :D
