Hardware Compatibility
Decklink Duo 2 Output.....Help!
Hi Everyone, first of all say hello to all in this very cooperative forum. Great one!
I've been trying for days to make my decklink duo 2 work full duplex and no luck yet. No problem on getting 2,3 or 4 inputs working but I can't get the card work as output. For what I do (Mostly corporate conferences) I need to configure the card as 2 in 2 out or 3 in 1 out. I have tried every single "Decklink video render" output but nothing. Instead I get the following message:
"The selected external renderer device is in use or does not support the selected format. Please check your external output settings and try again"
Of course I did try different resolutions with every single frame rate and still nothing.
If any of you can help me I will own you one
Thanks!
Cristian
Joined: 8/2/2013(UTC) Posts: 1,100   Location: Fairhope, Alabama USA Thanks: 592 times Was thanked: 204 time(s) in 170 post(s)
You'll need to use the Blackmagic Video Utility app to change the port routing, then it should work in vMix. The app was installed when you installed the driver.
- Tom
sinc747 wrote:You'll need to use the Blackmagic Video Utility app to change the port routing, then it should work in vMix. The app was installed when you installed the driver.
- Tom Second what Tom said. I use this card in a external AKiTiO Thunder2 PCIe Box and use in similar way with 4in or 3 in 1 out etc depending on the need. Needs to be configured in the Blackmagic Desktop Video Setup application.
Thanks very much for your reply
I did not mention it but I have done all the configuration on the blackmagic desktop video setup. I can get 2,3 or 4 input but no output. I set it up as following
decklink 1= 1 decklink 2= 3 decklink 3= 2 decklink 4= None
With this I get the error I typed before on vMix
I know this card works for everyone so I'm conscious that I'm doing something wrong but seriously I have tried so many times that I got lost.
If anyone can send me pics of their configuration on the blackmagic software and the external output window on vmix I would appreciate it.
Thanks in advance
Cristian
In my config the card is just set with all i/o routed to their own connector. In vMix I can set them up as input or output. As long as there is no input set on the same i/o, you can set the output to the card on any connector.
Did you solve this ? I plan to buy the DeckLink Duo myself but for me it is crucial to get 3 Inputs with one output. Is it audio embeded ?
best David
Hi David , yes I finally did it today. On the blackmagic desktop video utility set all input to a single connector (1 to 1). Sorry Im not on my vmix machine so I can’t be more specific at the moment. Let me know if you need help.
Cris
Joined: 4/5/2020(UTC) Posts: 9  Location: Trondheim Thanks: 1 times
3 years later... we still need help on this topic :D
