Joined: 6/29/2011(UTC) Posts: 316   Location: Florida Thanks: 6 times Was thanked: 35 time(s) in 34 post(s)
Is there an API call to step the "T-Bar" by an incremental value ? in either direction + or -
Egriswold wrote:Is there an API call to step the "T-Bar" by an incremental value ? in either direction + or - No but you can set it to a value between 0 and 255. eg. api?Function=SetFader&Value=120 I have just made a request to martin to make some changes with the API, most specifically being able to retrieve more info than is currently available.
