NDI
Add NDI source via API?
Joined: 2/7/2018(UTC) Posts: 45 Location: Saint Louis
Thanks: 4 times Was thanked: 4 time(s) in 3 post(s)
Hi All, I'm learning HTTP Commands, can't seem to figure out how to add an NDI input? What am I doing wrong here? http://192.168.0.4:8088/api/?Function=AddInput&NDI|= "NDI SOURCE" Thanks in advance! Mike
Also, I'd like to pause/play a youtube clip with HTTP API? Am I looking at the browser section of the shortcuts for this?
Thanks: 2 times Was thanked: 46 time(s) in 32 post(s)
MikeBenke wrote:Hi All, I'm learning HTTP Commands, can't seem to figure out how to add an NDI input? What am I doing wrong here? http://192.168.0.4:8088/api/?Function=AddInput&NDI|= "NDI SOURCE" Thanks in advance! Mike You probably need to URL encode the string. raw quotes are likely a problem URL Encoding
Thanks for the Link to W3 livepad! I am still at a loss though... I was hoping someone could give me an example string of what to type in. Specifically to add an NDI source via HTTP API. I could probably figure out what to replace on my end in terms of name of NDI source, etc. That reminds me... Is there a way to specify or reserve the input number the new source creates? Perhaps there is a better way of doing this that I am unaware of but.. I'd like to keep my API string that triggers an overlay on/off from Panamation's workspace the same every time I run vMix regardless of what sources I may have added or active. Is this possible? To me, this means that either I must A) load a saved project file that keeps Panam in the same input location or B) create an API command that Add's Panam as an input (via NDI) and dictates that it always be the same input number (let's say 997) If possible, what would that string look like? This? 127.0.0.1:8088/api/?Function=AddInput997&NDI=GlobeCaster_Panamation Then I could write my api command to run the overlay1 with input 997 and it would always work because those inputs would be reserved like this: http://127.0.0.1:8088/api?Function=OverlayInput1&Input=997 While we are at it, what do I type in if I want to jog frame back and forth on a clip using regular vMix? 127.0.0.1:8088/api/?Function=SetPosition..... Thanks again, I promise you'll only have to show me once :)
I don't know the vMix API, so perhaps this will not help at all, but NDI sources are named "Device Name (Channel Name)"
In your example, if Panamation is running on a computer called "WinPC" and Panamation uses the channel name of "GlobeCaster_Panamation", the full NDI name would be "WinPC (GlobeCaster_Panamation)"
Perhaps vMix doesn't do it this way, but this is how TriCaster sees NDI sources (I'm guessing that pretty much all applications will be similar since they all use the same NDI DLL).
Kane Peterson NewTek
From the help files:
NDI
NDICommand
Send specified command to NDI source
Value = Command
Value,Input
NDISelectSourceByIndex
Value = Index 0-100
Value,Input
NDISelectSourceByName
Value = Name
Value,Input
NDIStartRecording
Input
NDIStopRecording
Input
You might want to move this question to the API section of this forum 3rd Party Software and Development
Joined: 8/21/2015(UTC) Posts: 324   Location: Cornwall, Ontario, Canada Thanks: 18 times Was thanked: 80 time(s) in 60 post(s)
There is no API command to add an NDI source at this time.. only Source Types available to add are Video Image Photos Xaml VideoList Colour AudioFile Flash PowerPoint If NDI was there, the command would look like. http://xxx.xxx.xxx.xxx:8088/api/?Function=AddInput&Value= Type|ComputerName%20InputName http://xxx.xxx.xxx.xxx:8088/api/?Function=AddInput&Value= NDI|ComputerName%20Display1orhttp://xxx.xxx.xxx.xxx:8088/api/?Function=AddInput&Value= NDI|ComputerName%20(Display1)orhttp://xxx.xxx.xxx.xxx:8088/api/?Function=AddInput&Value= NDI|ComputerName%20%28Display1%29 %20 is for the hex value for space character... %28 is for the hex value for ( character... %29 is for the hex value for ) character... If I get a chance in the next months or so or I will try and write an HTTP API converter app for each command in vMix which will output the correct HTTP API command
 1 user thanked desmar for this useful post.
Thank You Desmar. I think a converter would be brilliant for guys like me who just can't seem to wrap their heads around the lingo.
NDI
