vMix Call
VMIX DUAL CALLER VIDEO FREEZES WHILE STREAMING
My last face live stream with 2 video calls,2 local cameras, and multiview with 4 screens, got to 100% total CPU usage, video from one of the guest callers froze while the audio continued. I can't find the origin of the freeze video, here's my config: ASUS Laptop, i5 processor, 12gb ram, windows 10, vmix trial, one hdmi camera via Atem intensity shuttle one laptop camera internet: 75 Mbps download and 25 Mbps upload. I am unsure if the hardware is the issue, the vmix configuration, the internet or all of it. Heres the facebook streaming video link https://www.facebook.com.../videos/538342669843648/Appreciate any help
@ Johnny
CPU at 100% is not a good thing and likely the major cause of your issue. Which graphics card does your laptop use? Were you recording and streaming simultaneously? Were your vMix settings the same as your streaming settings? The more work you ask your computer to do, the higher the CPU usage will be and something you should try to mitigate as much as possible.
I'd say you are pushing the limits of what an i5 laptop can do. Particularly if it doesn't have a high end NVidia dedicated video chip to help it and if it's a dual core i5 and not a quad core i5.
 2 users thanked Speegs for this useful post.
Thank you Icestream and Speegs, I posted a reply so this maybe twice, I have an
Intel® Core™ i5 7200U Processor, Windows 10 Premium
Chipset Integrated Intel® CPU
Memory DDR4 2133MHz SDRAM Onboard Memory, up to 12 GB SDRAM
Graphic Integrated Intel HD Graphics 520.
I have reduced all settings to 720p and put all Vmixcall returns on the lowest, then stream at 850 kbps, that seems to work on up to 2 callers.
Which laptop configuration should I look up to in order to have maybe 4 callers at the same time and streaming to Facebook at 1280x720 maybe?
Everything IceStream and Speegs alluded to, you don't have an Nvidia card in the laptop. Plus the i5 7200U is a dual core processor, with not as much speed as some of the quad core 2nd gen i7's.
 1 user thanked SportsNetUSA.net for this useful post.
AFTER A QUICK RESEARCH I FOUND THIS ASUS for $1,450
Processor Intel® Core™ i7 6700HQ Processor, Windows 10 Home Chipset Intel® HM170 Chipset Memory 16 GB DDR4 2133MHz SDRAM 2 x SO-DIMM socket Display 17.3" (16:9) LED-backlit FHD (1920x1080)
Graphic NVIDIA GeForce GTX 1060, with GDDR5, 6GB VRAM
Hard Drives: 1TB 7200RPM SATA HDD Solid State Drives: 256GB SATA3 SSD
I appreciate any suggestions, my streaming laptop will not be used for games by the way.
@ Johnny That is certainly much more in line with vMix's "reference system" for laptops and likely to give you much smoother and stable streams @ 720p to Facebook. vMix takes advantage of gaming technology and relies heavily on the graphics card for video processing. Streaming and recording are typically CPU intensive and so having better than average components there will make a difference. Ice
Joined: 11/23/2016(UTC) Posts: 330  Location: USA Thanks: 179 times Was thanked: 26 time(s) in 25 post(s)
Hi
If I were getting a laptop today I’d make sure it had Thunderbolt support.
What do others thoughts about that....
Rowby
vMix Call
