Joined: 12/9/2012(UTC) Posts: 3 Location: Kolkata,India.
i cant here audio from web browser input. what is the solution or setting? Audio mixer show CefBrowserInstance but cant here audio
@ uttam laha
Is the "Automatically Mix Audio" box ticked in Settings? (Browser Input cog wheel -> General -> "Automatically Mix Audio" tic box about mid page)
Joined: 11/9/2014(UTC) Posts: 106   Location: Copenhagen, Denmark Thanks: 22 times Was thanked: 17 time(s) in 16 post(s)
It might be the same issue I've been having. If you don't use the motherboard audio as the default device, audio won't work in web browser inputs.
I use a USB headset, so I've plugged in a random minijack into the motherboard audio, set it as the windows default and set the USB headset as headphones in vMix.
I hope this helps if you haven't solved it already :)
