rinaldo
#1 Posted : Monday, July 10, 2017 9:35:10 AM(UTC)
rinaldo
Hi friends, I'm planning to buy a Blackmagic Ultrastudio HD Mini to use with MacBook Pro (mid 2015 with bootcamp Win10)
Ultrastudio uses USB C (thunderbolt 3) and the Macbook Pro uses thunderbolt 2.
Will it work using Apple Thunderbolt 3 to Thunderbolt 2 adapter?
Whit this solution I can use Ultrastudio HD mini also with my descktop pc that has USB C on Z270 MSI Motherboard.
monamiga
#2 Posted : Thursday, July 20, 2017 6:13:02 AM(UTC)
monamiga
Philippines
Not yet, as Blackmagic UltraStudio HD Mini is not supported yet by vMix. Blackmagic UltraStudio HD Mini works with Thunderbolt 3 only. It does not work with Thunderbolt 3 to Thunderbolt 2 adapter.
As of this time, it only support the following software,
Blackmagic Design: DaVinci Resolve, Fusion
Apple: Final Cut Pro X
Adobe: Premiere Pro CC, After Effects CC, Photoshop CC
Avid: Media Composer, Pro Tools
Autodesk: Smoke
Steinberg: Cubase, Nuendo
I hope soon vMix will support this device.
Mon
for more info:
https://www.bhphotovideo...SDXAuNjq83MaAqByEALw_wcB
rinaldo
#3 Posted : Friday, July 21, 2017 8:23:49 AM(UTC)
rinaldo
Autodesk: Smoke
Mon
for more info:
Thanks Monamiga! Finally I got Ultrastudio Mini Recorder and Elgato HD60s!
monamiga
#4 Posted : Friday, July 21, 2017 8:29:03 AM(UTC)
monamiga
Philippines
I was able to make UltraStudio HD Mini works as vMix external output device not yet on key & fill(soon). By Steve suggestion here at vMix forum and Editor Rams at
DVE
#5 Posted : Thursday, August 10, 2017 7:33:17 PM(UTC)
DVE
monamiga wrote:
I was was able make UltraStudio HD Mini works as vMix external output device not yet on key & fill(soon). By Steve suggestion here at vMix forum and Editor Rams at
You got this to work on a 2015 Macbook Pro?!
monamiga
#6 Posted : Wednesday, August 16, 2017 4:53:47 AM(UTC)
monamiga
Philippines
Hi DVE,
I did on a MSI PX60 Laptop. It will never work on a 2015 Macbook Pro because it has on Thunderbolt 2. UltraSudio HD Mini works only in Thunderbolt 3.
MonAmiga
