Hardware Compatibility
Ultrastudio HD mini on Macbook Pro with Thunderbolt 2
Joined: 11/29/2016(UTC) Posts: 75  Location: Italy Thanks: 1 times Was thanked: 4 time(s) in 3 post(s)
Hi friends, I'm planning to buy a Blackmagic Ultrastudio HD Mini to use with MacBook Pro (mid 2015 with bootcamp Win10)
Ultrastudio uses USB C (thunderbolt 3) and the Macbook Pro uses thunderbolt 2. Will it work using Apple Thunderbolt 3 to Thunderbolt 2 adapter?
Whit this solution I can use Ultrastudio HD mini also with my descktop pc that has USB C on Z270 MSI Motherboard.
Joined: 5/20/2017(UTC) Posts: 63   Location: Philippines Thanks: 171 times Was thanked: 3 time(s) in 2 post(s)
Not yet, as Blackmagic UltraStudio HD Mini is not supported yet by vMix. Blackmagic UltraStudio HD Mini works with Thunderbolt 3 only. It does not work with Thunderbolt 3 to Thunderbolt 2 adapter. As of this time, it only support the following software, Blackmagic Design: DaVinci Resolve, Fusion Apple: Final Cut Pro X Adobe: Premiere Pro CC, After Effects CC, Photoshop CC Avid: Media Composer, Pro Tools Autodesk: Smoke Steinberg: Cubase, Nuendo I hope soon vMix will support this device. Mon for more info: https://www.bhphotovideo...SDXAuNjq83MaAqByEALw_wcB
monamiga wrote: Not yet, as Blackmagic UltraStudio HD Mini is not supported yet by vMix. Blackmagic UltraStudio HD Mini works with Thunderbolt 3 only. It does not work with Thunderbolt 3 to Thunderbolt 2 adapter. As of this time, it only support the following software, Blackmagic Design: DaVinci Resolve, Fusion Apple: Final Cut Pro X Adobe: Premiere Pro CC, After Effects CC, Photoshop CC Avid: Media Composer, Pro Tools Autodesk: Smoke Steinberg: Cubase, Nuendo I hope soon vMix will support this device. Mon for more info: https://www.bhphotovideo...SDXAuNjq83MaAqByEALw_wcB Thanks Monamiga! Finally I got Ultrastudio Mini Recorder and Elgato HD60s!
I was able to make UltraStudio HD Mini works as vMix external output device not yet on key & fill(soon). By Steve suggestion here at vMix forum and Editor Rams at
Joined: 6/2/2016(UTC) Posts: 40  Location: Everett, WA Thanks: 11 times Was thanked: 3 time(s) in 3 post(s)
monamiga wrote:I was was able make UltraStudio HD Mini works as vMix external output device not yet on key & fill(soon). By Steve suggestion here at vMix forum and Editor Rams at You got this to work on a 2015 Macbook Pro?!
Hi DVE,
I did on a MSI PX60 Laptop. It will never work on a 2015 Macbook Pro because it has on Thunderbolt 2. UltraSudio HD Mini works only in Thunderbolt 3.
MonAmiga
