Systems
1U Rack Based System
Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Hello Everyone!
Has anyone built a vMix system in a 1U rack mount like the vMix go? I am looking for an extremely portable system to encode 1080HD video with 4 SDI inputs and ingesting RTSP feeds.
Pictures, Boards, Enclosure ideas?
Thanks!
Joined: 8/3/2015(UTC) Posts: 325 Location: Chicago, IL
Sorry that is the system I meant.
I could not find that page and thought they have taken them off the market.
Has anyone built a custom 1U computer?
Joined: 10/1/2016(UTC) Posts: 117  Thanks: 88 times Was thanked: 52 time(s) in 31 post(s)
Was looking to build a VMix 1U for a flight case to replace our ATEM TV Studio, but I want to do more hardware testing to see if a good quality GPU card is needed to ingest or RTSP feeds and 4 cameras. Getting one ePCI card into a 1U is a challenge so if it needs a gpu card, then you will be looking at a 4U case. So I may just go 4U as all my cards I have now in Thunderbolt expansion boxes will work/fit.
If you do build a 1U let us know the results as a compact solution would be great for small flight cases and quick setups.
-sheldon
Joined: 3/28/2016(UTC) Posts: 172   Location: SACRAMENTO Thanks: 6 times Was thanked: 27 time(s) in 22 post(s)
SHMD wrote:Was looking to build a VMix 1U for a flight case to replace our ATEM TV Studio, but I want to do more hardware testing to see if a good quality GPU card is needed to ingest or RTSP feeds and 4 cameras. Getting one ePCI card into a 1U is a challenge so if it needs a gpu card, then you will be looking at a 4U case. So I may just go 4U as all my cards I have now in Thunderbolt expansion boxes will work/fit.
-sheldon let me know about this i'm doing the same thing. i'm using a 6U maybe an 8U due to other equipment for my mobile streaming flight kit but just started putting it together and researching 2 days ago so i would be interested to see what your doing if your much farther along :)
Joined: 12/3/2013(UTC) Posts: 123   Location: Arizona Thanks: 8 times Was thanked: 6 time(s) in 6 post(s)
Any updates on your 1u builds?
Joined: 3/7/2012(UTC) Posts: 506  Location: The Netherlands Thanks: 9 times Was thanked: 45 time(s) in 39 post(s)
on a side note: I use an intel nuc i7 with tb3 port to akitio box with bm duo2 with 4 sdi inputs,
smaller than a 1u system, and very powerfull and flexible. it comes with brackets to attach to a monitor.
if you want you can put it in an enclosure. mouse and keybord by bluetooth.
if you need more info let me know.
stefan
 1 user thanked h2video.nl for this useful post.
Systems
