BluestemVideo
#1 Posted : Wednesday, December 14, 2016 1:45:33 PM(UTC)
BluestemVideo
Hello Everyone!
Has anyone built a vMix system in a 1U rack mount like the vMix go?
I am looking for an extremely portable system to encode 1080HD video with 4 SDI inputs and ingesting RTSP feeds.
Pictures, Boards, Enclosure ideas?
Thanks!
Cpilcher
#2 Posted : Wednesday, December 14, 2016 2:19:03 PM(UTC)
Cpilcher
vMix created this a while ago, there are specs on the page. not sure if you have seen this yet.
Chuck
http://www.vmix.com/products/vmix-u.aspx
BluestemVideo
#3 Posted : Thursday, December 15, 2016 6:21:46 PM(UTC)
BluestemVideo
Sorry that is the system I meant.
I could not find that page and thought they have taken them off the market.
Has anyone built a custom 1U computer?
SHMD
#4 Posted : Friday, December 23, 2016 9:17:55 AM(UTC)
SHMD
Canada
Was thanked: 52 time(s) in 31 post(s)
Was looking to build a VMix 1U for a flight case to replace our ATEM TV Studio, but I want to do more hardware testing to see if a good quality GPU card is needed to ingest or RTSP feeds and 4 cameras.
Getting one ePCI card into a 1U is a challenge so if it needs a gpu card, then you will be looking at a 4U case. So I may just go 4U as all my cards I have now in Thunderbolt expansion boxes will work/fit.
If you do build a 1U let us know the results as a compact solution would be great for small flight cases and quick setups.
-sheldon
NiBTour
#5 Posted : Friday, January 6, 2017 11:10:06 PM(UTC)
NiBTour
-sheldon
let me know about this i'm doing the same thing. i'm using a 6U maybe an 8U due to other equipment for my mobile streaming flight kit but just started putting it together and researching 2 days ago so i would be interested to see what your doing if your much farther along :)
g-mo
#6 Posted : Tuesday, July 4, 2017 7:23:03 PM(UTC)
g-mo
Any updates on your 1u builds?
h2video.nl
#7 Posted : Wednesday, July 5, 2017 2:37:09 AM(UTC)
h2video.nl
on a side note: I use an intel nuc i7 with tb3 port to akitio box with bm duo2 with 4 sdi inputs,
smaller than a 1u system, and very powerfull and flexible. it comes with brackets to attach to a monitor.
if you want you can put it in an enclosure. mouse and keybord by bluetooth.
if you need more info let me know.
stefan
thanks 1 user thanked h2video.nl for this useful post.
SHMD on 9/15/2017(UTC)
g-mo
#8 Posted : Wednesday, July 5, 2017 9:11:46 PM(UTC)
g-mo
Post it up!
