Where did my MPEG codec go?
I'm sure I'm not the only one this has happened to, but I couldn't find any reference when I searched. We're running the latest version on a Win7 64bit machine All of a sudden we start getting a warning/alert that MPEG is not a supported codec. Since when? and how do I get it back. I've tried a fresh install, altho I didn't uninstall the old version 1st?
Any Ideas? Thanks
What context do you get the warning?
Mine looks like this: lilricky attached the following image(s):  IMG_1159(1).JPG (972kb) downloaded 17 time(s).You cannot view/download attachments. Try to login or register.
kjones9999 wrote:Try Mpeg using "FFMPEG". Thanks, I'll try it, but whats the difference in quality? and where did the other codec go?
Its same codec, but in some versions of windows its a licensing issue. FFMPEG has it a version built in.
Hi. Windows 10, does not support Window Media Center WMC found in win8.1 and I think win7. So I searched the net and I found WMC for win10. After I installed, it worked I hope this answer solve this problem.
Thanks all, But the MPEG-2 worked fine two weeks ago. Why did it go away? It also still works in a companion computer. I'm not a big fan of WNV files.
Have you tried using ffmpeg yet?
kjones9999 wrote:Have you tried using ffmpeg yet? I'm back at work tonight, I'll give it a try
kjones9999 wrote:Have you tried using ffmpeg yet? We tried it last night. Seems to work fine. Thanks
