lilricky
#1 Posted : Friday, June 30, 2017 9:21:54 AM(UTC)
lilricky
I'm sure I'm not the only one this has happened to, but I couldn't find any reference when I searched.
We're running the latest version on a Win7 64bit machine All of a sudden we start getting a warning/alert that MPEG is not a supported codec. Since when? and how do I get it back. I've tried a fresh install, altho I didn't uninstall the old version 1st?
Any Ideas?
kjones9999
#2 Posted : Saturday, July 1, 2017 1:59:55 AM(UTC)
kjones9999
What context do you get the warning?
hak
#3 Posted : Saturday, July 1, 2017 7:48:42 AM(UTC)
hak
Hi.
check my post
https://forums.vmix.com/...aspx?g=posts&t=11031
Do you think your problem like mine for using mpeg?
check the pictures inside of it.
lilricky
#4 Posted : Saturday, July 1, 2017 11:03:56 AM(UTC)
lilricky
Mine looks like this:
lilricky attached the following image(s):
kjones9999
#5 Posted : Saturday, July 1, 2017 11:27:11 PM(UTC)
kjones9999
Try Mpeg using "FFMPEG".
lilricky
#6 Posted : Sunday, July 2, 2017 9:25:08 AM(UTC)
lilricky
Thanks,
I'll try it, but whats the difference in quality?
and where did the other codec go?
kjones9999
#7 Posted : Sunday, July 2, 2017 9:49:57 AM(UTC)
kjones9999
Its same codec, but in some versions of windows its a licensing issue. FFMPEG has it a version built in.
hak
#8 Posted: : Sunday, July 2, 2017 2:30:27 PM(UTC)
hak
Hi.
Windows 10, does not support Window Media Center WMC found in win8.1 and I think win7. So I searched the net and I found WMC for win10. After I installed, it worked
I hope this answer solve this problem.
lilricky
#9 Posted : Monday, July 3, 2017 9:49:16 AM(UTC)
lilricky
Thanks all,
But the MPEG-2 worked fine two weeks ago. Why did it go away?
It also still works in a companion computer. I'm not a big fan of WNV files.
kjones9999
#10 Posted : Monday, July 3, 2017 8:30:17 PM(UTC)
kjones9999
Have you tried using ffmpeg yet?
lilricky
#11 Posted : Tuesday, July 4, 2017 10:37:00 AM(UTC)
lilricky
I'm back at work tonight, I'll give it a try
lilricky
#12 Posted : Wednesday, July 5, 2017 1:46:04 PM(UTC)
lilricky
We tried it last night. Seems to work fine.
