DeckLink Duo 2 unable to collect the signal 1080P,use win7 x64 or win10 x64,720P ok
The manufacturer does not return the goods.too bad
Joined: 2/16/2017(UTC) Views messages in topic : 180 Location: Denmark
Thanks: 27 times Was thanked: 19 time(s) in 16 post(s)
Check that the drivers have been installed and that SDI 1-4 have been configured conrrectly in Blackmagic Desktop Video Setup.
Joined: 3/20/2014(UTC) Posts: 2,721   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
Check your cams are outputting 1080p correctly. Decklink Duo 2 supports all resolutions up to 1080p50/60.
Your issue might also come from the converters, if you are using cheap hdmi 2 sdi converters.
Guillaume
