r@wisla
#1 Posted : Friday, June 30, 2017 9:21:42 AM(UTC)
r@wisla
Was thanked: 40 time(s) in 37 post(s)
The issue started yesterday, an hour before streaming. After launching vMix it crashed... No specific error specified, just: "program stopped working because of a problem. Windows system will close the program and let you know if there is a solution / [debug] [close program]". Debugging does nothing, of course...
I didn't install any new hardware, ma latest windows update was from 19.06.2017. I uninstalled it, but the issue remained.
I did the streaming, because vMix 32-bit version was OK.
It was 19.0.0.2something version, so today I installed the latest. Unfortunately vMix is still down after starting the program. 32-bit version too...
The system:
Dell Precision i7-2860QM, 16GB RAM, nVidia Quadro 2000M; old Magewell USB 3 SDI capture device, but without it vMix crashes too.
Where should I look for..?
#2 Posted : Friday, June 30, 2017 11:22:20 AM(UTC)
Was thanked: 4711 time(s) in 1615 post(s)
Right click Start Menu, select Event Viewer and open up Windows Logs \ Application.
Look for the red X entry for vMix which will provide some information as to what is causing the problem.
Most likely a third party program or library is hooking into vMix and causing problems.
It will be listed in the event log as a dll
r@wisla
#3 Posted : Friday, June 30, 2017 2:47:41 PM(UTC)
r@wisla
Event viewer indicates module that caused the error: C:\WINDOWS\SYSTEM32\d3d9.dll
This file was last modified 21.11.2016.
Any idea what could and how to fix this?
r@wisla attached the following image(s):
#4 Posted : Friday, June 30, 2017 8:51:23 PM(UTC)
Looks like Direct3D is damaged on the system. You can try updating the graphics driver, but failing that it sounds like a reinstall of Windows may be required.
r@wisla on 7/1/2017(UTC), Zetor1980 on 7/1/2017(UTC)
r@wisla
#5 Posted : Saturday, July 1, 2017 2:50:47 AM(UTC)
r@wisla
Update of GPU driver solved the problem.
thanks 1 user thanked r@wisla for this useful post.
