vMix crash - where to start? (Solved)
Joined: 8/5/2013(UTC) Posts: 281  Location: Poland Thanks: 29 times Was thanked: 40 time(s) in 37 post(s)
The issue started yesterday, an hour before streaming. After launching vMix it crashed... No specific error specified, just: "program stopped working because of a problem. Windows system will close the program and let you know if there is a solution / [debug] [close program]". Debugging does nothing, of course...
I didn't install any new hardware, ma latest windows update was from 19.06.2017. I uninstalled it, but the issue remained.
I did the streaming, because vMix 32-bit version was OK.
It was 19.0.0.2something version, so today I installed the latest. Unfortunately vMix is still down after starting the program. 32-bit version too...
The system: Dell Precision i7-2860QM, 16GB RAM, nVidia Quadro 2000M; old Magewell USB 3 SDI capture device, but without it vMix crashes too.
Where should I look for..?
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
Right click Start Menu, select Event Viewer and open up Windows Logs \ Application. Look for the red X entry for vMix which will provide some information as to what is causing the problem.
Most likely a third party program or library is hooking into vMix and causing problems. It will be listed in the event log as a dll
Martin vMix
Event viewer indicates module that caused the error: C:\WINDOWS\SYSTEM32\d3d9.dll This file was last modified 21.11.2016. Any idea what could and how to fix this? r@wisla attached the following image(s):  bledy1.png (20kb) downloaded 91 time(s). bledy2.png (34kb) downloaded 78 time(s).You cannot view/download attachments. Try to login or register.
Looks like Direct3D is damaged on the system. You can try updating the graphics driver, but failing that it sounds like a reinstall of Windows may be required.
Update of GPU driver solved the problem.
 1 user thanked r@wisla for this useful post.
