No video on VLC streaming input
I'm trying to set up an input from an RTMP stream, using the VLC for vMix plugin, but I am only getting audio, no video. If I open the stream on VLC I get video, so I know the stream is fine.
Does anyone have any suggestions?
Joined: 3/20/2014(UTC) Posts: 2,721 ![Man Man](/Themes/yafpro/male.gif) ![France France](/Content/images/flags/FR.png) Location: Bordeaux, France Thanks: 243 times Was thanked: 794 time(s) in 589 post(s)
Hi
what are the codecs used inside your RTMP feed ?
![thanks](/Themes/yafpro/heart_small.png) 1 user thanked DWAM for this useful post.
H264 for video, AAC for audio. Here's the output from VLC's codec information ![UserPostedImage](http://i.imgur.com/YnICc55.png)
That's strange... It seems everything's correct...
Did you try the genuine Flash/RTMP input type ?
when I try to use the Flash/RTMP input it tells me to install Flash for IE, but when I try to install that it says it's already integrated with IE (it's a Windows Server 2016 machine)
Quote:it's a Windows Server 2016 machine oh! I'm not sure vMix is supposed to be running on a windows server OS. You should write to support@vmix.com to make sure. Maybe, this is the reason why you have issues.
I managed to get flash installed and now I'm getting video, thanks.
Good to know if it works with Flash RTMP but still doesn't work with VLC, right? It's strange. Maybe you should ask support anyway to make sure...
Joined: 10/13/2012(UTC) Posts: 1,162 ![Australia Australia](/Content/images/flags/AU.png) Location: Melbourne Thanks: 220 times Was thanked: 199 time(s) in 181 post(s)
There are certain windows elements (such as .net framework 3.5)that are not installed on Server2016 by default. It could be that this is why you have this issue.
