kuroyume
#1 Posted : Thursday, June 22, 2017 4:03:54 PM(UTC)
kuroyume
I'm trying to set up an input from an RTMP stream, using the VLC for vMix plugin, but I am only getting audio, no video. If I open the stream on VLC I get video, so I know the stream is fine.
Does anyone have any suggestions?
#2 Posted : Friday, June 23, 2017 8:29:34 AM(UTC)
Hi
what are the codecs used inside your RTMP feed ?
kuroyume on 6/23/2017(UTC)
kuroyume
#3 Posted : Friday, June 23, 2017 9:27:09 AM(UTC)
kuroyume
H264 for video, AAC for audio.
Here's the output from VLC's codec information
#4 Posted : Friday, June 23, 2017 11:17:47 AM(UTC)
That's strange... It seems everything's correct...
Did you try the genuine Flash/RTMP input type ?
kuroyume
#5 Posted : Friday, June 23, 2017 11:35:46 AM(UTC)
kuroyume
when I try to use the Flash/RTMP input it tells me to install Flash for IE, but when I try to install that it says it's already integrated with IE (it's a Windows Server 2016 machine)
#6 Posted : Friday, June 23, 2017 11:57:23 AM(UTC)
oh! I'm not sure vMix is supposed to be running on a windows server OS.
You should write to support@vmix.com to make sure. Maybe, this is the reason why you have issues.
kuroyume
#7 Posted : Friday, June 23, 2017 11:57:41 AM(UTC)
kuroyume
I managed to get flash installed and now I'm getting video, thanks.
#8 Posted : Friday, June 23, 2017 12:02:28 PM(UTC)
Good to know if it works with Flash RTMP but still doesn't work with VLC, right?
It's strange. Maybe you should ask support anyway to make sure...
ask
#9 Posted : Friday, June 23, 2017 6:05:44 PM(UTC)
ask
There are certain windows elements (such as .net framework 3.5)that are not installed on Server2016 by default. It could be that this is why you have this issue.
