thinkcustom
#1 Posted : Friday, June 9, 2017 4:43:22 PM(UTC)
thinkcustom
Windows just did an update now i'm getting this error when I turn on External Output.
StartStopExternal
Selected Video Format is not supported by this device: bmdModeHD1080p2997
Error HRESULT E_FAIL has been returned from a call to a COM component.
I'm using a BMD Decklink Quad 2 with 4 cameras in and 1 output to my livestream.com broadcaster box. Everything has been working fine until windows did an auto update yesterday.
Vmix 19.0.0.50
Decklink software 10.9.3
Windows 10
i7-6700
8GB RAM
4 items Windows updated sense last know working config (Sunday June 4th)
1) Security Update for Adobe Flash Player (kbid-402082a)
2) KB4021572
3) KB4020102
4) Visual C++ 2008 x86 Runtime - v9.0.3729.01
Next step it to uninstall the updates one by one to see if that fixes it.
Any help or ideas you guys can give would be appreciated.
thanks 1 user thanked thinkcustom for this useful post.
DMSMK on 5/4/2021(UTC)
jeru
#2 Posted : Saturday, June 10, 2017 5:41:58 PM(UTC)
jeru
I had a similar problem when trying to record today in vmix 19.0.0.50.
I upgraded to latest version 19.0.0.53 still same problem
Then I went backwards and realised that vmix 19.0.49 worked and recorded as expected.
I haven't installed windows update since May 12th
I'm running
Windows 7 sp1
I5-2500
16 GB RAM
I'm using BMD Intensity Shuttle USB3
DVS Version 10.8.5
Even just record a prerecord video, vmix still do the Fail in version 19.0.0.50 and .53
Jesper
PS has done some more testing and changed my MP4 record settings from H264High to H264Baseline the I could record in vmix 19.0.0.53
thinkcustom
#3 Posted : Saturday, June 10, 2017 6:51:57 PM(UTC)
thinkcustom
Uninstalling the updates didn't do anything so I rolled back windows 10 to an earlier state and now its working fine on 19.0.0.50. But doing so corrupted up my installation of BMD software so I had to re-download an older version to fully uninstall it and then I installed the lasted version.
I have yet to try version 19.0.0.53
DMSMK
#4 Posted : Tuesday, May 4, 2021 6:15:14 AM(UTC)
DMSMK
Canada
This exact same issue just happened for me.
I would receive the same error message when trying to use an external recorder. No settings had been changed, and we had successful shows and recordings just last week.
Finally figured out bloody Windows ran automatic updates. (can't seem to figure out how to completely disable that on Windows 10)
Anywho uninstalled 2/3 of the updates listed on the history list, but couldn't uninstall the 3rd item which was a service pack. Restarted the system, same problem. Seems there's no way to uninstall the service pack, and we thought we were stuck.
Did a system recovery on the whole PC to bring it back to the previous build, and voila everything works again.
Windows Updates = Unhappy Vmix
lindend
#5 Posted : Monday, September 29, 2025 1:07:39 PM(UTC)
lindend
Just ran into this issue. Had an unexpected and forced Windows update on a working system with a Decklink 8k Pro.
After the system rebooted, I'm getting this error.
Desktop Video Setup detects the 8k Pro and it appears to be functional.
Updated the BlackMagic Desktop Video drivers, updated vMix from 27 to the latest 28. Nothing has helped.
Did anyone ever figure out a solution to this issue without rolling back Windows?
dmwkr
#6 Posted : Monday, September 29, 2025 6:53:36 PM(UTC)
dmwkr
Was thanked: 154 time(s) in 138 post(s)
Double check all the settings in the Desktop Video Software on the correct output signal and especially the connector mappings. Most likely the mappings have been reset. Set them again to this (other card, but same procedure):
https://www.vmix.com/kno...k-quad2-to-be-8-channels
thanks 1 user thanked dmwkr for this useful post.
lindend on 9/30/2025(UTC)
lindend
#7 Posted : Tuesday, September 30, 2025 1:50:02 PM(UTC)
lindend
Fixed the connector mappings and things worked. Thanks for the suggestion.
Any idea why an OS update would cause this?
Similar Topics
E.Recording Error HRESULT E_FAIL has been returned from a call to a COM component (General Discussion)
by Valholler 11/12/2020 3:35:31 AM(UTC)
Error HRESULT E_FAIL (General Discussion)
by vanis 3/14/2014 4:03:37 PM(UTC)
