2 Pages<12
stevespaw
#21 Posted : Tuesday, May 23, 2017 11:19:32 AM(UTC)
stevespaw
Was thanked: 76 time(s) in 57 post(s)
I justed played a 3play .MOV in vMix just fine.
But I cannot play Kane's alphatest .mov.
Steve
#22 Posted : Tuesday, May 23, 2017 12:39:54 PM(UTC)
@ stevespaw
I can confirm that your SHQ.AVI clip works fine in vMix.
(provided you notify vMix with the tic box that the video has alpha channel when Inputting!)
BTW, cool 3D chrome text effect...
stevespaw
#23 Posted : Tuesday, May 23, 2017 2:06:36 PM(UTC)
stevespaw
OK so I tested with AE
1. AVI - Must Select the DCT option for alpha! the regular 4.2.2.4 did not have alpha in vMix
AVI
2. Same comp render with Quicktime and same NewTek codec setting.
will not import into vMix.
MOV
So I think it is the fact of using FFMPEG as the quicktime player or something. ??? My guess.
Steve
thanks 1 user thanked stevespaw for this useful post.
RandomStreamer on 7/10/2017(UTC)
RandomStreamer
#24 Posted : Monday, July 10, 2017 10:41:11 PM(UTC)
RandomStreamer
AVI
MOV
Steve
Using AVI w/ DCT worked out for me, thanks!
Digitalson
#25 Posted : Friday, July 14, 2017 1:41:56 AM(UTC)
Digitalson
Groups: Guests
How about a straight up MP4 that seams to work great in vmix with h264 codec and low CPU,I would love to see the h265 codec soon I've seen it before and is nice
vnick
#26 Posted : Monday, October 11, 2021 7:42:11 PM(UTC)
vnick
Hong Kong
Can anyone recommend a free tool to encode ProRes or Animation codecs to SpeedHQ with alpha?
EDIT: received this back from newtek support
I'm following up on your support inquiry.
Unfortunately, Adobe dropped support of SpeedHQ (well, QuickTime 32 bit, but that impacts SpeedHQ).
That means that using the older version of Quicktime is the right way to go.
If that helps, the alpha channels do need to be "straight" and not pre-multiplied.
You can do QuickTime Pro res 4:4:4:4 alpha and 4:2:2:4 alpha.
Saying that, there are some unofficial interesting facts:
Adobe provides a special EXE on request, that allows the installation of 2018 versions of its software.
Take a look here:
https://community.adobe..../11582836/highlight/true
And that thread is extremely interesting, even though not tested by us:
https://www.ffastrans.co...rum/viewtopic.php?t=1196
I hope that helps.
2 Pages<12
