grDancer
#1 Posted : Saturday, May 13, 2017 10:51:17 AM(UTC)
grDancer
Hi all,
I'm trying to control vmix social via another PC on my network. Both the main PC running Vmix and the remote PC are connected to the network using ethernet (not wireless).
I typed the address into chrome on the other PC, but it doesn't gain access. Page times out.
Can someone point me to a guide for how to set this up? Is it likely to be a windows firewall setting on my main PC? Or a router setting? Or something else?
in the help guide it says:
"Note: you may need to configure access to the web interface in your firewall or modem settings to allow remote access."
But I have no idea how to do that...
#2 Posted : Saturday, May 13, 2017 11:24:09 AM(UTC)
Hi
is the application vMixSocial already running when you try to access its web interface?
Does it work on the local PC ?
Can you access vMix WebController on port 8088 from the remote computer?
grDancer
#3 Posted : Saturday, May 13, 2017 12:53:47 PM(UTC)
grDancer
DWAM wrote:
Hi
thanks for answering!
It's already running on the main PC.
It works on the main PC.
I don't know how to access it on port 8088 - what does that mean?
grDancer
#4 Posted : Saturday, May 13, 2017 12:55:44 PM(UTC)
grDancer
The address it gives me is:
http://192.168.1.92:8089/
#5 Posted : Saturday, May 13, 2017 12:59:03 PM(UTC)
vMix has 2 web services:
first one is Web Controller, it runs on port 8088 by default
second one is Social which runs on port 8089
I wanted you to try if you can access to WebController from the remote computer
The address is then : http://192.168.1.92:8088/
grDancer
#6 Posted : Saturday, May 13, 2017 2:23:04 PM(UTC)
grDancer
8088 works, 8089 doesn't seem to...
#7 Posted : Saturday, May 13, 2017 2:30:21 PM(UTC)
Might be a firewall issue.
To make sure:
1. deactivate firewall on the vMix host and try again. If OK, check your firewall settings for port 8089 AND REACTIVATE FW ! ;o)
2. deactivate firewall on the remote computer, etc...
grDancer on 5/13/2017(UTC)
grDancer
#8 Posted : Saturday, May 13, 2017 5:51:54 PM(UTC)
grDancer
Worked a treat. Literally got it fixed 2 minutes before we went live, so thanks a lot!
