Vmix Social network setup problem
Thanks: 30 times Was thanked: 1 time(s) in 1 post(s)
Hi all,
I'm trying to control vmix social via another PC on my network. Both the main PC running Vmix and the remote PC are connected to the network using ethernet (not wireless).
I typed the address into chrome on the other PC, but it doesn't gain access. Page times out.
Can someone point me to a guide for how to set this up? Is it likely to be a windows firewall setting on my main PC? Or a router setting? Or something else?
in the help guide it says: "Note: you may need to configure access to the web interface in your firewall or modem settings to allow remote access."
But I have no idea how to do that...
Joined: 3/20/2014(UTC) Posts: 2,719   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
Hi
is the application vMixSocial already running when you try to access its web interface?
Does it work on the local PC ?
Can you access vMix WebController on port 8088 from the remote computer?
DWAM wrote:Hi
Can you access vMix WebController on port 8088 from the remote computer? thanks for answering! It's already running on the main PC. It works on the main PC. I don't know how to access it on port 8088 - what does that mean?
Quote:I don't know how to access it on port 8088 - what does that mean? vMix has 2 web services: first one is Web Controller, it runs on port 8088 by default second one is Social which runs on port 8089 I wanted you to try if you can access to WebController from the remote computer The address is then : http://192.168.1.92:8088/
8088 works, 8089 doesn't seem to...
Might be a firewall issue.
To make sure: 1. deactivate firewall on the vMix host and try again. If OK, check your firewall settings for port 8089 AND REACTIVATE FW ! ;o) 2. deactivate firewall on the remote computer, etc...
Worked a treat. Literally got it fixed 2 minutes before we went live, so thanks a lot!
