2 Pages12>
iansama
#1 Posted : Monday, May 8, 2017 8:54:34 AM(UTC)
iansama
I've been hearing a lot of folks say that quicktime sucks a lot of CPU but what's an alternative? I want to use a format that allows alpha channels and audio
(normally I use the animation codec inside of aftereffects for QT files)
mjgraves
#2 Posted : Wednesday, May 10, 2017 2:18:04 PM(UTC)
mjgraves
A series of PNG files.
iansama
#3 Posted : Thursday, May 11, 2017 11:34:51 AM(UTC)
iansama
last time I checked png seq doesn't carry audio, unless you know something i don't
#4 Posted : Thursday, May 11, 2017 11:53:15 AM(UTC)
@ iansama
It typically doesn't, BUT...
You can add an audio file to the folder and rename it to match the first image in the sequence and you should be good to go when loaded into vMix.
Some of the details are discussed here:
https://forums.vmix.com/...aspx?g=posts&t=10632
Hope that helps.
iansama on 5/11/2017(UTC)
#5 Posted : Thursday, May 11, 2017 11:53:37 AM(UTC)
iansama
#6 Posted : Thursday, May 11, 2017 12:18:33 PM(UTC)
iansama
thanks DWAM and IceSream, you guys replied with the same link within 15 seconds of each other -- great minds think alike ;)
I will check it out and report back :D
stevespaw
#7 Posted : Thursday, May 11, 2017 2:35:22 PM(UTC)
stevespaw
Was thanked: 76 time(s) in 57 post(s)
We use the NewTek codecs here now, they support alpha and audio. Much smaller files that QT animation also.
https://www.newtek.com/ndi/tools/
Steve
thanks 1 user thanked stevespaw for this useful post.
mjgraves on 5/12/2017(UTC)
Speegs
#8 Posted : Sunday, May 14, 2017 7:13:20 PM(UTC)
Speegs
Steve can you expand on that. Many tools on that page :) Is there a download to an Newtek video file format? I didn't see it. Or are you saying you use the Adobe plugin and send stuff real time from After Effects or Premier?
kane
#9 Posted : Sunday, May 14, 2017 9:17:40 PM(UTC)
kane
Installing NDI Tools on a PC will install the NewTek SpeedHQ codec. This codec supports alpha channel by choosing selection that has four digits of color space (like SpeedHQ 4:2:2:4 or 4:2:0:4).
There is also a OSX version of SpeedHQ that can be downloaded from http://new.tk/dl
The codecs are available on the bottom of the page.
Kane Peterson
NewTek
thanks 4 users thanked kane for this useful post.
sinc747 on 5/14/2017(UTC), Peter B on 5/15/2017(UTC), Speegs on 5/15/2017(UTC), mjgraves on 5/16/2017(UTC)
RandomStreamer
#10 Posted : Friday, May 19, 2017 8:47:19 AM(UTC)
RandomStreamer
Steve
Hi Steve,
I've been trying to use the newtek codecs with alpha channel, without success. I'm exporting the videos selecting the alpha option on Adobe After effects, but when I add them into VMIX the alpha doesnt work. I even tryied to tick the "this video contains alpha channel", while adding it.
It's possible that I'm missing something while exporting or importing, can you give me some more information so I get it to work?
I'm currently having huge performance issues by using multiple .mov animations into my production.
Thank you.
stevespaw
#11 Posted : Friday, May 19, 2017 3:40:32 PM(UTC)
stevespaw
Can you Export a PNG file of one of the frames and verify that it has alpha?
There are several Adobe setting that can affect this.
Steve
kane
#12 Posted : Saturday, May 20, 2017 1:37:26 AM(UTC)
kane
I just used After Effects 2017 and rendered out a QuickTime in the SpeedHQ 4:2:2:4 codec and loaded into my IP Series system (I don't have a vMix). Alpha channel was there. Must be a setting somewhere.
Kane Peterson
NewTek
ask
#13 Posted : Saturday, May 20, 2017 2:49:43 AM(UTC)
ask
Kane Peterson
NewTek
Kane, can you upload the .mov file and we can check it in vMix.
kane
#14 Posted : Saturday, May 20, 2017 5:49:05 PM(UTC)
kane
ask wrote:
Kane Peterson
NewTek
Here is a link to download my super awesome, mind blowing alpha channel animation!
https://1drv.ms/v/s!AvQUqb_Jvb0UhA0M0II2Mt8jhC9k
Kane Peterson
NewTek
RandomStreamer
#15 Posted : Saturday, May 20, 2017 6:42:07 PM(UTC)
RandomStreamer
Kane,
Vmix didn't recognice the file format, and I do have NDI Tools installed, I can even record with newtek codec.
VLC reports the codec is "SHQ3".
Am I doing something wrong?
thanks,
Felipe
kane wrote:
ask wrote:
Kane Peterson
NewTek
Kane Peterson
NewTek
kane
#16 Posted : Saturday, May 20, 2017 7:01:27 PM(UTC)
kane
I can't say. It works on my TriCaster and with After Effects without having to do anything special. I don't use vMix (just here to help with NDI questions). Perhaps someone else here knows if there is a step you are missing.
Kane Peterson
NewTek
#17 Posted : Saturday, May 20, 2017 7:22:58 PM(UTC)
@ kane
Same issue here...
None of my players are able to play your file (vMix, VLC, Quicktime, WindowsMediaPlayer)
vMix Error: Could not find elementary streams
EDIT: Also, the NewTek codecs in vMix are contained in AVI not MOV.
ask
#18 Posted : Saturday, May 20, 2017 8:32:34 PM(UTC)
ask
It opens in QT on my test machine quite happily but I get the same error as Ice when trying to open in vMix. have sent the error log to vMix support.
Also works fine in Vegas.
kane
#19 Posted : Saturday, May 20, 2017 10:07:01 PM(UTC)
kane
IceStream wrote:
@ kane
Same issue here...
- Current VLC Player doesn't support SpeedHQ, unless you are using VLC v3 betas.
- Apple's QuickTime Player will play the files at long as the NewTek codecs are installed (use QuickTime 7 on OSX systems).
- Windows MediaPlayer will not play any QuickTime codec beyond H.264.
- I have no idea about vMix.
The SpeedHQ codec is supported in both AVI and QuickTime files.
Kane Peterson
NewTek
stevespaw
#20 Posted : Tuesday, May 23, 2017 10:22:06 AM(UTC)
stevespaw
Here is a SpeedHQ .avi that I made in BluffTitler quickly.
SHQ .AVI video
It works perfect in vMix here.
Steve
Guest (10)
2 Pages12>
