Clocksmith
#1 Posted : Monday, May 8, 2017 5:33:57 AM(UTC)
Clocksmith
Hi All,
Have just had the ,vMix has stopped working error'. Any help would be hugely appreciated as I have some events coming up.
Log here:
Faulting application name: vMix64.exe, version: 19.0.0.46, time stamp: 0x590a900b
Faulting module name: VideoCaptureApi.dll_unloaded, version: 3.50.122.2122, time stamp: 0x58dba64c
Exception code: 0xc0000005
Fault offset: 0x00000000005a19d3
Faulting process ID: 0x394c
Faulting application start time: 0x01d2c7053569671c
Faulting application path: C:\Program Files (x86)\vMix\vMix64.exe
Faulting module path: VideoCaptureApi.dll
Report ID: b3d95f3f-3718-4586-a3c0-1940f862bc2e
Faulting package full name:
Faulting package-relative application ID:
- System
- Provider
[ Name] Application Error
- EventID 1000
[ Qualifiers] 0
Level 2
Task 100
Keywords 0x80000000000000
- TimeCreated
[ SystemTime] 2017-05-07T09:22:41.753176600Z
EventRecordID 4157
Channel Application
Computer DESKTOP-4NTLHEK
Security
- EventData
vMix64.exe
19.0.0.46
590a900b
3.50.122.2122
58dba64c
c0000005
00000000005a19d3
394c
01d2c7053569671c
VideoCaptureApi.dll
vMix V19.0.0.46
Windows 10
I7 4770k
32GB Ram
Asrock z87 Extreme9 AC mobo
Asus GTX 1050TI Graphics card
Blackmagic Ultrastudio mini recorder
Elgato HD60s
Blackmagic Decklink 4k
Matrox MX02 LE
Logitech Brio Webcam
Behringer UMC1820
Akai APC40 Midi controller
#2 Posted : Monday, May 8, 2017 12:08:55 PM(UTC)
VideoCaptureApi.dll is part of the Elgato driver, so it looks like the problem is with the Elgato driver unfortunately.
You can try seeing if they have an update available, otherwise you might need to contact them for a fix.
Clocksmith on 5/8/2017(UTC)
Clocksmith
#3 Posted : Monday, May 8, 2017 12:18:40 PM(UTC)
Clocksmith
OK, thanks. It's on the current version.
I'll reinstall and see if it happens again although I'm fairly sure I won't use it for an event if there's even the most remote chance that it will happen.
