Eyes.Only
#1 Posted : Sunday, April 9, 2017 7:28:29 PM(UTC)
Eyes.Only
I'm not finding anything in my searches.
If I use API calls to trigger fades or other simple changes, it would be nice to have an output pane to see response as well. Even a jpeg stream or something that could show it's current output. Is there any means? Something that either a third party app could include or a web based controller. Using the RMTP stream has far too much latency.
kjones9999
#2 Posted : Sunday, April 9, 2017 10:04:30 PM(UTC)
kjones9999
An NDI feed would seem to be called for here... you could also use a trigger to take a snapshot....
Eyes.Only
#3 Posted : Saturday, April 15, 2017 8:14:40 AM(UTC)
Eyes.Only
What code/applets are available for viewing an NDI feed?
#4 Posted : Saturday, April 15, 2017 8:37:01 AM(UTC)
You can use vMixUTC for this : https://forums.vmix.com/....aspx?g=posts&t=6468
In this video you will see a basic example of using UTC to create a user interface allowing to switch inputs aswell as having an integrated NDI monitor that shows the result of your switching. A perfect solution for specific use cases with remote or multiple vMix operators.
help : https://forums.vmix.com/...ts&m=34998#post34998
vMix UTC runs on Windows either on the same vMix host or any other computer on the same network
Guillaume
#5 Posted : Saturday, April 15, 2017 8:38:30 AM(UTC)
ndi monitor from the NDI TOOLS
