I'm not finding anything in my searches.
If I use API calls to trigger fades or other simple changes, it would be nice to have an output pane to see response as well. Even a jpeg stream or something that could show it's current output. Is there any means? Something that either a third party app could include or a web based controller. Using the RMTP stream has far too much latency.
An NDI feed would seem to be called for here... you could also use a trigger to take a snapshot....
What code/applets are available for viewing an NDI feed?
You can use vMixUTC for this : https://forums.vmix.com/....aspx?g=posts&t=6468In this video you will see a basic example of using UTC to create a user interface allowing to switch inputs aswell as having an integrated NDI monitor that shows the result of your switching. A perfect solution for specific use cases with remote or multiple vMix operators. help : https://forums.vmix.com/...ts&m=34998#post34998vMix UTC runs on Windows either on the same vMix host or any other computer on the same network Guillaume
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 319 times Was thanked: 1021 time(s) in 838 post(s)
Eyes.Only wrote:What code/applets are available for viewing an NDI feed? ndi monitor from the NDI TOOLS
