curtismacd31
#1 Posted : Friday, September 16, 2016 4:13:58 PM(UTC)
curtismacd31
I have a question, has anyone who has a dell alienware laptop tried using the Dell Alienware Graphics Amplifier for a capture card? I am thinking of trying this unit and putting a BMD QUAD or DUO 2 in for inputs. Has anyone tried this? on paper it seems like it may work.
1 x PCIe x16 slot
Fits a single full-length, dual-wide, PCI Express x16 graphics card
stevespaw
#2 Posted : Saturday, September 17, 2016 10:51:06 AM(UTC)
stevespaw
Was thanked: 76 time(s) in 57 post(s)
Why go with something so proprietary ?
Why not,
http://www.sonnettech.com/Product/echoexpress3d.html
Steve
Theochristo4
#3 Posted : Sunday, April 9, 2017 1:39:47 PM(UTC)
Theochristo4
I have also been trying to figure out if Alienware Graphics Booster will run a capture card.
The reason we would like to use the proprietary Dell box is for the proprietary cable & connector allowing for more connectivity with thunderbold/usb c ports.
Also no need for thunderbolt 3 to thunderbolt 2 adapter with the newer AW Laptops.
SportsNetUSA.net
#4 Posted : Monday, April 10, 2017 3:59:51 PM(UTC)
SportsNetUSA.net
From Alienware FAQ
Does it work in SLI/Crossfire
No, once plugged in, the internal Graphics card turns off
That could be a problem.
Have you asked Dell support if it can run a capture card?
curtismacd31
#5 Posted : Tuesday, April 11, 2017 8:21:40 PM(UTC)
curtismacd31
I ended up not doing this. I am however looking at using the graphics amplifier to put a GTX 1060 and give my vmix laptop a boost in performance over my 960M.
voyagermix
#6 Posted : Friday, May 17, 2019 7:08:58 AM(UTC)
voyagermix
Mexico
I want to do this, nobody else has checked it?
or how else can I connect AJA Io 4K Thunderbolt 2 to My Alienware?
