Hardware Compatibility
Dell Alienware Graphics Amplifier with PCIe Capture Crard
I have a question, has anyone who has a dell alienware laptop tried using the Dell Alienware Graphics Amplifier for a capture card? I am thinking of trying this unit and putting a BMD QUAD or DUO 2 in for inputs. Has anyone tried this? on paper it seems like it may work.
1 x PCIe x16 slot Fits a single full-length, dual-wide, PCI Express x16 graphics card
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 152 times Was thanked: 76 time(s) in 57 post(s)
I have also been trying to figure out if Alienware Graphics Booster will run a capture card. The reason we would like to use the proprietary Dell box is for the proprietary cable & connector allowing for more connectivity with thunderbold/usb c ports. Also no need for thunderbolt 3 to thunderbolt 2 adapter with the newer AW Laptops.
From Alienware FAQ Quote:Does it work in SLI/Crossfire No, once plugged in, the internal Graphics card turns off That could be a problem. Have you asked Dell support if it can run a capture card?
I ended up not doing this. I am however looking at using the graphics amplifier to put a GTX 1060 and give my vmix laptop a boost in performance over my 960M.
Joined: 2/10/2015(UTC) Posts: 34   Location: La Paz, MX Thanks: 9 times
I want to do this, nobody else has checked it? or how else can I connect AJA Io 4K Thunderbolt 2 to My Alienware?
