Feature Requests
Blur effect for multi-views
Now that we have so many multi-view layers, it would be useful to be able to blur inputs and layers to create the illusion of depth with each layer. This would work similarly to the sharpen function on each input, but perhaps might have adjustable settings for the blur level
 1 user thanked ask for this useful post.
Joined: 8/2/2013(UTC) Posts: 1,113   Location: Fairhope, Alabama USA Thanks: 607 times Was thanked: 207 time(s) in 173 post(s)
Joined: 4/14/2013(UTC) Posts: 264  Location: Australia Thanks: 35 times Was thanked: 38 time(s) in 36 post(s)
+1
I use this using an upstream mixer that has defocus. One trick is to defocus the wide shot and add a graphic for an opener and closer. Then mixing between the comp and the camera effectively pulls focus and loses the super. It's also a dynamic background for boxes.
You can defocus realtimne using Resolve in live mode but it ties up sdi resources.
Slightly blurring a chroma key background adds a shallow DOF filmic look and dimension. Lots of creative uses.
+ 1
Could prove to be useful
Joined: 3/30/2014(UTC) Posts: 224   Location: London, UK Thanks: 23 times Was thanked: 27 time(s) in 23 post(s)
+1 Add Layer depth too??? With Shadows???
Joined: 3/8/2016(UTC) Posts: 123 Location: Anniston, Alabama
+1
Add drops shadows and colored borders that are adjustable
Joined: 6/29/2016(UTC) Posts: 104 Location: Luxembourg
Thanks: 48 times Was thanked: 14 time(s) in 12 post(s)
Joined: 2/25/2014(UTC) Posts: 6 Location: Bendigo Australia
Thanks: 38 times Was thanked: 24 time(s) in 20 post(s)
+1, I see a lot of value for the blur effect. If it would be linkable to a controller, would be even better!
Joined: 4/6/2016(UTC) Posts: 84  Location: Sweden Thanks: 25 times Was thanked: 18 time(s) in 13 post(s)
Joined: 4/19/2014(UTC) Posts: 64  Location: United States Thanks: 4 times Was thanked: 5 time(s) in 5 post(s)
+1 for a Gaussian Blur Effect!
Joined: 9/30/2016(UTC) Posts: 5  Location: Ukraine, Ternopil
+1 for drop shadows and borders
Joined: 4/4/2016(UTC) Posts: 235  Location: Not Los Angeles CA Thanks: 86 times Was thanked: 28 time(s) in 23 post(s)
Thanks: 2 times Was thanked: 7 time(s) in 5 post(s)
Feature Requests
