JonnyNoblett
#1 Posted : Saturday, April 1, 2017 5:33:41 AM(UTC)
JonnyNoblett
I am running VMix Desktop Capture on an Alienware Alpha running a application.
I am seeing 28-30fps on the Capture when running it but when I bring it into VMix it is not achieving the same frame rate, it is jumpy.
I am running the NDI through Cat5e to a TP-Link Switch to TP-Link Powerlines then to the VMix Machine - could the issue be with the powerlines? What would be the best way to get the fastest connection with no loss in framerate? If I was to reconfigure to plug the VMix machine and Alpha into the same Switch would that provide the best solution?
The VMix Machine is:
MSI GT72VR 6RE(Dominator Pro)-234UK
Intel Core i7-6700HQ Quad Core Processor
17.3" Full HD Screen
Microsoft Windows 10 Home 64-bit,
16GB DDR4 RAM
128GB SSD + 1000GB HDD
Dedicated GeForce GTX 1070 8GB Graphics
#2 Posted : Saturday, April 1, 2017 5:37:48 AM(UTC)
Was thanked: 795 time(s) in 589 post(s)
Yes clearly
Yes clearly
NDI requires serious network setup.
Regards
Guillaume
JonnyNoblett
#3 Posted : Saturday, April 1, 2017 5:43:09 AM(UTC)
JonnyNoblett
If I was to use something like this and had all NDI sources and also VMix machine plugged in would that be the best solution?
https://www.amazon.co.uk...;keywords=tp+link+switch
#4 Posted : Saturday, April 1, 2017 5:51:53 AM(UTC)
Yes. You need to plug all your PCs on the same network with a gigabit switch and use at least CAT5e cables. CAT6 is better.
This switch should be perfectly fine.
JonnyNoblett
#5 Posted : Saturday, April 1, 2017 5:52:46 AM(UTC)
JonnyNoblett
Thanks for the help - I will be doing lots of testing this weekend and will report back. J
kane
#6 Posted : Saturday, April 1, 2017 1:17:37 PM(UTC)
kane
JonnyNoblett wrote:
I am running the NDI through Cat5e to a TP-Link Switch to TP-Link Powerlines then to the VMix Machine...
What PowerLine model? I've got TP-Link Powerline units model TL-PA9020P, which are rated at 2Gbit/s speed. However, in real-world performance I get around ~250mbit/s speeds. Powerline and NDI can work, but the actual performance of these units is typically much (MUCH!) lower than what they are rated. If you have any way to get a direct Ethernet connection, instead of Powerline, go that route. I would recommend Powerline over wireless connections.
Kane Peterson
NewTek
