Thanks: 23 times Was thanked: 3 time(s) in 3 post(s)
I am running VMix Desktop Capture on an Alienware Alpha running a application.
I am seeing 28-30fps on the Capture when running it but when I bring it into VMix it is not achieving the same frame rate, it is jumpy.
I am running the NDI through Cat5e to a TP-Link Switch to TP-Link Powerlines then to the VMix Machine - could the issue be with the powerlines? What would be the best way to get the fastest connection with no loss in framerate? If I was to reconfigure to plug the VMix machine and Alpha into the same Switch would that provide the best solution?
The VMix Machine is:
MSI GT72VR 6RE(Dominator Pro)-234UK Intel Core i7-6700HQ Quad Core Processor 17.3" Full HD Screen Microsoft Windows 10 Home 64-bit, 16GB DDR4 RAM 128GB SSD + 1000GB HDD Dedicated GeForce GTX 1070 8GB Graphics
Joined: 3/20/2014(UTC) Posts: 2,721   Location: Bordeaux, France Thanks: 243 times Was thanked: 794 time(s) in 589 post(s)
Quote:could the issue be with the powerlines? Yes clearly Quote:If I was to reconfigure to plug the VMix machine and Alpha into the same Switch would that provide the best solution? Yes clearly NDI requires serious network setup. Regards Guillaume
Yes. You need to plug all your PCs on the same network with a gigabit switch and use at least CAT5e cables. CAT6 is better.
This switch should be perfectly fine.
Thanks for the help - I will be doing lots of testing this weekend and will report back. J
JonnyNoblett wrote: I am running the NDI through Cat5e to a TP-Link Switch to TP-Link Powerlines then to the VMix Machine...
What PowerLine model? I've got TP-Link Powerline units model TL-PA9020P, which are rated at 2Gbit/s speed. However, in real-world performance I get around ~250mbit/s speeds. Powerline and NDI can work, but the actual performance of these units is typically much (MUCH!) lower than what they are rated. If you have any way to get a direct Ethernet connection, instead of Powerline, go that route. I would recommend Powerline over wireless connections. Kane Peterson NewTek
