Broachbilly
#1 Posted : Friday, March 31, 2017 8:52:26 PM(UTC)
Broachbilly
Hello .. I have two computers at my church
Streaming PC and Projection PC
Both are windows 10 32bit. Gigabyte network
I have vMix NDI running on the Projection PC.
I have Vmix 18 running on my streaming pc.
When I go to NDI input I see the projection pc with PowerPoint loaded but its black. Its labeled correctly
So I know Vmix sees the projection pc.
On the Projection PC and vMix NDI is showing error.
Getting this error message.
System.AccessViolationException: Attempted to read or write protected memory. This is often an indication that other memory is corrupt. at vMixDesktopCaptureLibrary
I read something close on Knowledge Base but it refereed to windows 7..
Broachbilly attached the following image(s):
#2 Posted : Friday, March 31, 2017 9:39:54 PM(UTC)
Was thanked: 4726 time(s) in 1618 post(s)
Would it be possible to copy and paste the full error message here? Looks like part of it got cut off.
Is PowerPoint maximized and running fullscreen on the display? vMix Desktop Capture can't capture hidden or minimized windows, so that is something to check also.
Broachbilly
#3 Posted : Saturday, April 1, 2017 3:00:16 AM(UTC)
Broachbilly
here is complete error
at vMixDesktopCaptureLibrary.ID3D11DeviceContext.Map(ID3D11Texture2D pResource, UInt32 Subresource, D3D11_MAP MapType, UInt32 MapFlags, D3D11_MAPPED_SUBRESOURCE& pMappedResource)
at vMixDesktopCaptureLibrary.DXGICapture.Capture(DesktopCaptureData& d, Rectangle r)
at vMixDesktopCaptureLibrary.DesktopCaptureServer._CaptureThread()
an yes PPT was full screen
#4 Posted : Sunday, April 2, 2017 9:45:05 PM(UTC)
This error means something is not right with the graphics on the computer being captured.
Usually making sure windows is up to date and the latest drivers are installed will fix it.
Failing that you can go into Settings in desktop capture and untick Use GPU Acceleration
Similar Topics
Visca / NDI Error Message (General Discussion)
by lbrentevans 9/8/2021 9:32:03 AM(UTC)
NDI error - desktop capture black (NDI)
by north_beach 9/25/2016 1:02:19 AM(UTC)
ndi error on launch (NDI)
by aftersun 7/13/2016 12:30:27 PM(UTC)
