Joined: 1/13/2010(UTC) Posts: 5,327  Location: Gold Coast, Australia Was thanked: 4733 time(s) in 1623 post(s)
vMix 9 Preview is now available to download. Please note this is a preview release, so there may still be some bugs to work out. You can report any issues here. The final release will be out within the next couple of weeks. Download: http://www.vmix.com.au/download/vmix9preview.exeChanges:* RTSP Support for Teradek Cube and other H.264 and AAC sources. RTSP can also be used as a Video Delay source. * Stinger Transitions (Set "Stinger Cut Point" from Overlay settings) * Added support for Image Sequences (PNG, BMP etc) to be used with Stinger Transitions. * Improved Audio Sync. (Eliminated delay and reduced dropped samples) * Countdown feature added to Titles, count down or up and play/pause/stop timer. * Added Premultiplied Alpha checkbox * PlayList (M3U) now support relative paths * Video Delay settings such as MultiView automatically added to saved clips. * Improved Chroma Key algorithm preserves yellows and oranges. * Fixed Photos thumbnails in wrong order * F1-F12 shortcut keys will work within the Text Editor. * Fixed issue with mirrored sources and MultiView * Shortcuts can be set to Global or saved in Presets (Local) * Added support for Avermedia Live Gamer HD * Fixed freezing issue with Windows 8 * Fixed issue with HDV audio with some codecs Regards, Martin vMix
Hi Martin, This is great! I've just started testing, and my first observation is that the alpha channel on lagarith encoded files don't seem to work in vMix 64 bit. Here's a sample file: https://dl.dropbox.com/u...113800/Stinger%20ESL.aviThese files worked fine in vMix 8, just to be clear. Edit: I can confirm that .mov files with transparency are still fine in 32 bit vMix. Thanks! Andrew.
Joined: 1/23/2013(UTC) Posts: 65  Thanks: 3 times Was thanked: 7 time(s) in 5 post(s)
Thanks Martin.
I'll enjoy testing the transition cut-point feature.
I'll keep v9 away from the live webcasts, however. ;-)
Best,
Michael
Hi Martin.
Well done for the amazing work you have made! There're two things I would like to suggest for the new version. First - after several tests of capturing via firewire, we found that the resolution of the stream is 1440x1080, but as you know the program doesn't support this resolution. I know it's not a popular format, but it would be great if you add it. And second - for profesional shooting and broadcasting it is very important the buttons for switching the cameras to do the action on "push" position, not on "release". On every analog video mixer the action is on push. Because if you're shooting a music concert for example, it's important to switch the cams on beats, and that's very hard with vMix now. So that will be great improve.
Thank you in advance!
Best Regards!
Hi uKc,
Could you describe in some more detail what you mean by push? Are you referring to the fade bar? On the video mixers we have tried the videos stay in the preview and program positions all the way until the fade has been completed.
Martin vMix
Joined: 6/11/2012(UTC) Posts: 39  Location: jakarta Thanks: 34 times Was thanked: 12 time(s) in 7 post(s)
In Fullscreen mode settings (on/off), does not work. When Restart Application, always in fullscreen.
On the stinger transition, it'd be more useful if the cut time were defined on the input, and simply have a "stinger transition" checkbox on the overlay. That'd allow us to use stinger transitions of differing length in a single overlay channel. Not massively important as my current method using autohotkey works fine, but it'd be nice to have it built in.
I've done some testing with RTSP, and I couldn't get vMix to work with an RTSP stream from crtmpserver (http://www.rtmpd.com/) but it worked fine with VLC (I used VLC as an RTSP proxy in front of crtmpserver), so I suspect the issue is with crtmpserver. Any suggestions on logs or debugging I can enable on the vMix end to troubleshoot?
I _think_ I noticed a bug where the video delay on an RTSP input got disassociated from the RTSP input if there was a connection error. I'll try to recreate that bug tonight, and do some testing with my Avermedia Live Gamer HD.
Thanks! Andrew.
The download has been updated with a revised version. (9.0.0.90) Changes:* Fixed display issue with Avermedia Live Gamer HD * Turned on audio sync for separate Audio Input * Added checkbox to enable alpha channel when opening Lagarith AVI * Unchecking Fullscreen had no effect on startup. Same download link as before:http://www.vmix.com.au/download/vmix9preview.exe
Rank: Guest
Groups: Guests
hi martin, first, cool improvements on this new v9. customize recording name file is nice, thank you so much. i`m having a similar issues as grimble has with rtsp. vmix (both x86 and x64) don`t play my rtsp source from the link bellow: rtsp://www.espiritosanto.cc:1945/ies_tv/ies_tv this link is working fine on vlc, surely it can be fixed. regards, melody www.espiritosanto.cc
Thanks for the example stream melody. I'll see what can be done to get it working.
Martin vMix
Thanks: 1 times Was thanked: 2 time(s) in 1 post(s)
I too can't acces rtsp stream from my cam.. i get a 401 Unathorized error when i click on OK after having put the rtsp string... That same string plays fine in VLC...
just to specify, url to acces my camera stream is rtsp://admin:admin@192.168.1.108:554/cam/realmonitor?channel=1&subtype=0
of course you can't access it because its on my private network, just wanted to show the kind of url i need to enter to view stream.
Hi Martin, I've decided to make an illustration of what I mean, to make it easier for understanding. Illustration
uKc wrote:Hi Martin, I've decided to make an illustration of what I mean, to make it easier for understanding. Illustration In more programmer-y terms, it sounds like you want the event to fire on the OnKeyDown event, not on the OnKeyUp event.
Excellent work Martin, I'm still playing with it so not sure if I've figured it all out just yet, but things seem to have progressed well on the scoreboard (clock)front, but I'm wondering if there is a way (or code) to advance the score with a shortcut key (i.e. +1 each time it is pressed) the "set text" option only ascribes a predetermined "value" and thus the score still needs to be manually changed within the text editor, or maybe I'm missing something.
SetText can be used with a value of +=1 or +=2 etc to add to the existing score.
Another preview release with a few changes. (9.0.0.91) * Fixed RTSP buffering issue * Fixed RTSP pausing issue every few seconds with some sources * Added support for using RTSP behind some firewalls and modems * Added support for more RTSP streams * Shortcuts triggered on key-down rather than key-up * Basic Authentication for RTSP added Download: http://www.vmix.com.au/download/vmix9preview.exeI'm particularly interested in seeing if the RTSP issues reported above have been fixed. I've tested Teradek Cube, Wowza Media Server, VLC and QuickTime Streaming Server Regards, Martin vMix
Quote:* Shortcuts triggered on key-down rather than key-up Thank you very much for this! (: And just to ask again about adding the 1440x1080 resolution?
Hi Martin,
First up, thanks for the quick response!
I tested RTSP with crtmpserver, and it seems to work well - except when I've gotten it to run at 720p60 the audio sometimes drops out after about a second. At 30 frames it works fine, though I'll do more testing.
The Lagarith checkbox doesn't work in 64 bit vMix - it works in 32 bit though.
