GaspareNet
#1 Posted : Thursday, March 16, 2017 12:31:12 PM(UTC)
GaspareNet
If you open a file .xaml with vMix Titler Designer program crashes
see Attachment
GaspareNet attached the following image(s):
#2 Posted : Thursday, March 16, 2017 1:29:11 PM(UTC)
Was thanked: 1013 time(s) in 832 post(s)
no attachment
GaspareNet
#3 Posted : Thursday, March 16, 2017 1:43:08 PM(UTC)
GaspareNet
Attachment added.
Which only the size limits for attached video?
#4 Posted : Thursday, March 16, 2017 1:49:50 PM(UTC)
are you trying to open an existing title or one you modified or designed
The error does not tell much
GaspareNet
#5 Posted : Thursday, March 16, 2017 1:57:42 PM(UTC)
GaspareNet
I open a file of a Xaml templates I bought
#6 Posted : Thursday, March 16, 2017 2:00:19 PM(UTC)
Does it contain any graphics?
GaspareNet
#7 Posted : Thursday, March 16, 2017 2:06:54 PM(UTC)
GaspareNet
video where you see the problem
video crash
#8 Posted : Thursday, March 16, 2017 2:15:41 PM(UTC)
Not all xaml files are supposed to be opened with Title Designer
As Doggy explained, only files created for vMix using the WPF User Controls can be used.
XAML is a language used for many purposes, none of them are compatible with everything.
Check the doc for this:
http://www.vmix.com/help...veloperInformation1.html
GaspareNet on 3/16/2017(UTC)
#9 Posted : Thursday, March 16, 2017 2:26:42 PM(UTC)
Did you buy the Xaml templates as titles for vmix (as such advertised) ?
Do they run in vmix itself ?
seeing the code of one might help
ps
my own (Blend)titles might crash too in the editor while they run just fine in vMix ;-)
GaspareNet
#10 Posted : Thursday, March 16, 2017 4:12:27 PM(UTC)
GaspareNet
I bought an online animated tempates realized for vMix. It works.
I just want to make small changes. Change color or move an object. I have to use vMix Title Designer? Should I use Blend? What program should I use?
#11 Posted : Thursday, March 16, 2017 4:16:00 PM(UTC)
they are animated as you say so definitely not edit in title designer but in blend (or manual with a text editor )
They are probably way to complex for title designer to cope with
Hard to say without seeing the code or even if there is codebehind involved with them
GaspareNet
#12 Posted : Thursday, March 16, 2017 4:59:40 PM(UTC)
GaspareNet
Thanks for the answers!
I will try to use the blend to change the templates
Bandit62
#13 Posted : Sunday, March 19, 2017 8:21:35 AM(UTC)
Rank: Guest
Groups:
I am having an issue with the supplied Scoreboard templates in vMix....I have some fairly long names, and they do not fit in the area designed for them.. I have to make them small, and sometimes they are too small to read clearly.....how do I adjust that space so it can be wider to accept these long names.....Thank you.
#14 Posted : Sunday, March 19, 2017 8:35:14 AM(UTC)
You simply have to make your own graphics and xaml templates according to your needs.
Bandit62
#15 Posted : Sunday, March 19, 2017 7:22:37 PM(UTC)
Rank: Guest
Groups:
I started to play with the code, and was able to make adjustments to get a bigger space for the titles in the Scoreboard....I can now use longer names....I edited the code.....mind you, I am not a code writer, but I have a little understanding, and I tweaked it until I got what I wanted....I can share what I did if anyone wants to have it....
#16 Posted : Monday, March 20, 2017 1:44:19 PM(UTC)
@Matou
please create your own topic to share such information which is completely irrelevant to the current topic.
Matou on 3/20/2017(UTC)
