vMix Titler Designer crashes
Joined: 3/14/2017(UTC) Posts: 9  Location: Italy Thanks: 3 times
If you open a file .xaml with vMix Titler Designer program crashes see Attachment GaspareNet attached the following image(s):  titler-designer-crash.jpg (30kb) downloaded 1 time(s).You cannot view/download attachments. Try to login or register.
Attachment added. Which only the size limits for attached video?
are you trying to open an existing title or one you modified or designed
The error does not tell much
I open a file of a Xaml templates I bought
Does it contain any graphics?
Not all xaml files are supposed to be opened with Title Designer As Doggy explained, only files created for vMix using the WPF User Controls can be used. XAML is a language used for many purposes, none of them are compatible with everything. Check the doc for this: http://www.vmix.com/help...veloperInformation1.html
Did you buy the Xaml templates as titles for vmix (as such advertised) ? Do they run in vmix itself ? seeing the code of one might help
ps my own (Blend)titles might crash too in the editor while they run just fine in vMix ;-)
I bought an online animated tempates realized for vMix. It works. I just want to make small changes. Change color or move an object. I have to use vMix Title Designer? Should I use Blend? What program should I use?
they are animated as you say so definitely not edit in title designer but in blend (or manual with a text editor ) They are probably way to complex for title designer to cope with Hard to say without seeing the code or even if there is codebehind involved with them
Thanks for the answers! I will try to use the blend to change the templates
Rank: Guest
Groups: Guests
I am having an issue with the supplied Scoreboard templates in vMix....I have some fairly long names, and they do not fit in the area designed for them.. I have to make them small, and sometimes they are too small to read clearly.....how do I adjust that space so it can be wider to accept these long names.....Thank you.
You simply have to make your own graphics and xaml templates according to your needs.
Rank: Guest
Groups: Guests
I started to play with the code, and was able to make adjustments to get a bigger space for the titles in the Scoreboard....I can now use longer names....I edited the code.....mind you, I am not a code writer, but I have a little understanding, and I tweaked it until I got what I wanted....I can share what I did if anyone wants to have it....
@Matou
please create your own topic to share such information which is completely irrelevant to the current topic.
