Vmix19beta and vMix18 on same machine?
You have been a member since:: 11/28/2016(UTC) Posts: 14 Location: Salzburg
Hi, I would love to try vMix19 Beta with vMix call. I just wonder if I can have to versions of vMix on the same machine? Or does the install of Beta19 on a machine running vMix18 harm my Installation of 18? Because we are productive with that machine I would appreciate your advice. Thx Chris
Just install into another directory
My habit is to create a snapshot of the boot volume of my production machine using a backup tool. Then instal the new software. Doesn't take long. Ensures a recovery path.
mjgraves wrote:My habit is to create a snapshot of the boot volume of my production machine using a backup tool. Then instal the new software. Doesn't take long. Ensures a recovery path. Thanks. So you think installing in another directory will be not safe enough? And perhaps corrupting the vmix18?
Digisaurier wrote:mjgraves wrote:My habit is to create a snapshot of the boot volume of my production machine using a backup tool. Then instal the new software. Doesn't take long. Ensures a recovery path. Thanks. So you think installing in another directory will be not safe enough? And perhaps corrupting the vmix18? That might be perfectly safe, but I think it's fiddly. I prefer to have a known good image that I can revert to if necessary. Also, I build my systems such that the boot volume is an SSD that contains only the OS & Apps. No user data. That makes it really easy to image & restore, using another disk on the same system to hold the images.
