Digisaurier
#1 Posted : Friday, March 10, 2017 8:54:14 AM(UTC)
Digisaurier
I would love to try vMix19 Beta with vMix call. I just wonder if I can have to versions of vMix on the same machine?
Or does the install of Beta19 on a machine running vMix18 harm my Installation of 18? Because we are productive with that machine I would appreciate your advice.
Thx
Chris
#2 Posted : Friday, March 10, 2017 9:01:44 AM(UTC)
Just install into another directory
Digisaurier on 3/10/2017(UTC)
mjgraves
#3 Posted : Friday, March 10, 2017 1:33:55 PM(UTC)
mjgraves
My habit is to create a snapshot of the boot volume of my production machine using a backup tool. Then instal the new software. Doesn't take long. Ensures a recovery path.
Digisaurier
#4 Posted : Friday, March 10, 2017 1:39:22 PM(UTC)
Digisaurier
Thanks. So you think installing in another directory will be not safe enough? And perhaps corrupting the vmix18?
mjgraves
#5 Posted : Friday, March 10, 2017 1:46:00 PM(UTC)
mjgraves
That might be perfectly safe, but I think it's fiddly. I prefer to have a known good image that I can revert to if necessary.
Also, I build my systems such that the boot volume is an SSD that contains only the OS & Apps. No user data. That makes it really easy to image & restore, using another disk on the same system to hold the images.
