Joined: 10/30/2013(UTC) Posts: 290 Location: The Netherlands
Thanks: 6 times Was thanked: 21 time(s) in 15 post(s)
In my setup when vMix starts, a title is displayed in the program output (with overlay4). how can I simply let it disappear automatically after 5 minutes? I set the duration timer, but that doesn't work and the countdown shows a timer that I don't need.
Joined: 3/20/2014(UTC) Posts: 2,720   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
Hi if you want you can do this very easily with vMixUTC https://forums.vmix.com/...aspx?g=posts&t=6468 It takes 30 seconds to setup: Create a Timer Widget, set it to 5 minutes with "reverse" option to make it a countdown Fill the "On Completion" field with a command name like "Overlay4Off" Now create a Button Widget and give it a name Tick the "execute" box and write "Overlay4Off" in the link field Click the "script" + sign Select "execlink" in the dropdown menu and select "OverlayInputOff" in the function menu and select 4 in the overlay number Now start the countdown. When it reaches 0:00, the command "Overlay4Off" is sent to auto execute the Button command. Et voila! Longer to write than to do! ;o) Guillaume
Thanks, but UTC needs Dotnet4.5, I like to keep my setup as tight as possible.
What is the function of the title duration anyway? Is there maybe a better way to show the title with transparency over the program output?
vMixUTC can run on another PC than your vMix host.
Sorry I don't really understand your 2 questions. There is no function for defining a title duration. This can be done by associating a countdown timer to a command for removing the overlay. This exactly what I explained above. Titles are supposed to be used with an overlay or within a multiview (which is also an overlay)
I see now that the 'duration' clock in the title editor is meant for animations. I already have a script running that starts streaming after 2 minutes, I will use it also for generating an Overlay4off call.
Joined: 6/4/2014(UTC) Posts: 81  Location: USA Thanks: 40 times Was thanked: 9 time(s) in 9 post(s)
Within the Overlay Settings, there is a duration setting. We use this to remove overlays automatically after 30 seconds. I don't know how long you can set this but worth the look.
 1 user thanked Video Dave for this useful post.
Thanks, that's a simple solution, although it needs a free overlaychannel.
It's important to use frames in stead of ms, because 10.000 is the maximum allowed value for ms.
With frames greater delays are possible.
Thanks: 5 times Was thanked: 8 time(s) in 8 post(s)
You can set trigger for that input in Vmix
Trigger: OnOverlayIn Function: OverlayInput4Out Delay: 30000
When you set that input on ANY overlay it clear out Overlay 4 after 30 sec.
 1 user thanked kol0 for this useful post.
Thanks, I overlooked the trigger function.
However the maximum delay here is unfortunately 30 seconds and I need 5 minutes.
