wwdv
#1 Posted : Sunday, March 5, 2017 6:39:00 PM(UTC)
wwdv
Was thanked: 21 time(s) in 15 post(s)
In my setup when vMix starts, a title is displayed in the program output (with overlay4).
how can I simply let it disappear automatically after 5 minutes?
I set the duration timer, but that doesn't work and the countdown shows a timer that I don't need.
#2 Posted : Sunday, March 5, 2017 6:52:16 PM(UTC)
Hi
if you want you can do this very easily with vMixUTC
https://forums.vmix.com/...aspx?g=posts&t=6468
It takes 30 seconds to setup:
Create a Timer Widget, set it to 5 minutes with "reverse" option to make it a countdown
Fill the "On Completion" field with a command name like "Overlay4Off"
Now create a Button Widget and give it a name
Tick the "execute" box and write "Overlay4Off" in the link field
Click the "script" + sign
Select "execlink" in the dropdown menu and select "OverlayInputOff" in the function menu and select 4 in the overlay number
Now start the countdown. When it reaches 0:00, the command "Overlay4Off" is sent to auto execute the Button command.
Et voila!
Longer to write than to do! ;o)
Guillaume
wwdv
#3 Posted : Sunday, March 5, 2017 7:11:09 PM(UTC)
wwdv
Thanks, but UTC needs Dotnet4.5, I like to keep my setup as tight as possible.
What is the function of the title duration anyway?
Is there maybe a better way to show the title with transparency over the program output?
#4 Posted : Sunday, March 5, 2017 7:30:23 PM(UTC)
vMixUTC can run on another PC than your vMix host.
Sorry I don't really understand your 2 questions.
There is no function for defining a title duration. This can be done by associating a countdown timer to a command for removing the overlay. This exactly what I explained above.
Titles are supposed to be used with an overlay or within a multiview (which is also an overlay)
wwdv
#5 Posted : Sunday, March 5, 2017 7:46:29 PM(UTC)
wwdv
I see now that the 'duration' clock in the title editor is meant for animations.
I already have a script running that starts streaming after 2 minutes, I will use it also for generating an Overlay4off call.
Video Dave
#6 Posted : Tuesday, March 7, 2017 2:09:56 PM(UTC)
Video Dave
Within the Overlay Settings, there is a duration setting.
We use this to remove overlays automatically after 30 seconds.
I don't know how long you can set this but worth the look.
thanks 1 user thanked Video Dave for this useful post.
wwdv on 3/7/2017(UTC)
wwdv
#7 Posted : Tuesday, March 7, 2017 2:29:06 PM(UTC)
wwdv
Thanks, that's a simple solution, although it needs a free overlaychannel.
It's important to use frames in stead of ms, because 10.000 is the maximum allowed value for ms.
With frames greater delays are possible.
kol0
#8 Posted : Tuesday, March 7, 2017 3:04:25 PM(UTC)
kol0
Was thanked: 8 time(s) in 8 post(s)
You can set trigger for that input in Vmix
Trigger: OnOverlayIn
Function: OverlayInput4Out
Delay: 30000
When you set that input on ANY overlay it clear out Overlay 4 after 30 sec.
thanks 1 user thanked kol0 for this useful post.
wwdv
#9 Posted : Tuesday, March 7, 2017 3:44:27 PM(UTC)
wwdv
Thanks, I overlooked the trigger function.
However the maximum delay here is unfortunately 30 seconds and I need 5 minutes.
Similar Topics
Title duration and delay limitations (General Discussion)
by SpelingMistakes 3/31/2016 12:34:25 PM(UTC)
