#1 Posted : Friday, February 3, 2017 2:24:59 PM(UTC)
May I request the option of naming a recording (startrecording) with a shortcut similar to using the snapshot shortcut making it possible to name them on the fly with api calls etc
We have the naming date available when needed for this
richardgatarski
#2 Posted : Friday, February 3, 2017 5:14:38 PM(UTC)
richardgatarski
Hi doggy,
I think I requested something similar around this time last year: Improvements for how the Recording file name is managed. Are you requesting something similar, or different?
#3 Posted : Friday, February 3, 2017 5:29:09 PM(UTC)
@richardgatarski
is similar to your second point.
one could argue to change the name during or after the recording has finished per a script but that's problematic at times depending on the format one is saving to
As i have the data ready to be used in the filename for the hundreds of short individual recordings at a time using an external to rename through the API would be very very helpfull as a sequential numbering or alike isn't usefull to me for referencing quickly (could be like individual athletes)
#4 Posted : Wednesday, February 8, 2017 5:43:09 AM(UTC)
other solutions ?
#5 Posted : Tuesday, February 28, 2017 11:37:26 AM(UTC)
Bump
also requested here
Add the parameter "File name" to Shortcut StartRecording
If not per shortcut per se maybe at least through the HTTP protocol
Renaming hundreds up to over a thousand short clips saved after compared to using the available data during one event to save with in our case .....
Appreciate the consideration
#6 Posted : Wednesday, August 30, 2017 5:03:05 AM(UTC)
even more applicable for v2x
No need for a asking popup, just as API (httprequest) option
please, pretty please
Vegazz
#7 Posted : Tuesday, October 31, 2023 11:26:44 PM(UTC)
Vegazz
Netherlands
+1, weird enough after all these years there is still not a structural fix for this. Let's hope this +1 can make the difference.
#8 Posted : Tuesday, October 31, 2023 11:47:59 PM(UTC)
Well i didn't wait for it for 7 years ;-)
The solutions have been available by the addition of vMix scripting (before htat it was solved using external scripting) ;-)
using a Script makes it even more flexible ;-)
The solution principle has been posted in the forum somewhere : lookup last recording and rename it to your liking ;-)
Vegazz
#9 Posted : Friday, February 16, 2024 1:21:16 AM(UTC)
Vegazz
Netherlands
Couldn't find it when searching for recording, name, rename etc. Any chance of pointing me in the right direction?
#10 Posted : Friday, February 16, 2024 2:01:59 AM(UTC)
https://forums.vmix.com/...rded-clip-name#post76144
https://forums.vmix.com/...ecord-Filename#post91423
jet on 2/16/2024(UTC)
Similar Topics
Recording File Name Incremental Numbers (Feature Requests)
by narcus 1/15/2021 7:32:54 PM(UTC)
Proper Recording File Name Requester (Feature Requests)
by Jim_C 12/20/2018 8:29:16 AM(UTC)
Improvements for how the Recording file name is managed (Feature Requests)
by richardgatarski 1/10/2015 6:36:52 AM(UTC)
