Joined: 12/27/2012(UTC) Posts: 5,522  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
May I request the option of naming a recording (startrecording) with a shortcut similar to using the snapshot shortcut making it possible to name them on the fly with api calls etc We have the naming date available when needed for this
@richardgatarski
is similar to your second point.
one could argue to change the name during or after the recording has finished per a script but that's problematic at times depending on the format one is saving to
As i have the data ready to be used in the filename for the hundreds of short individual recordings at a time using an external to rename through the API would be very very helpfull as a sequential numbering or alike isn't usefull to me for referencing quickly (could be like individual athletes)
Bump also requested here Quote:Add the parameter "File name" to Shortcut StartRecording If not per shortcut per se maybe at least through the HTTP protocol Renaming hundreds up to over a thousand short clips saved after compared to using the available data during one event to save with in our case ..... Appreciate the consideration
even more applicable for v2x No need for a asking popup, just as API (httprequest) option
please, pretty please
+1, weird enough after all these years there is still not a structural fix for this. Let's hope this +1 can make the difference.
Originally Posted by: Vegazz  +1, weird enough after all these years there is still not a structural fix for this. Let's hope this +1 can make the difference. Well i didn't wait for it for 7 years ;-) The solutions have been available by the addition of vMix scripting (before htat it was solved using external scripting) ;-) using a Script makes it even more flexible ;-) The solution principle has been posted in the forum somewhere : lookup last recording and rename it to your liking ;-)
Originally Posted by: doggy  Originally Posted by: Vegazz  +1, weird enough after all these years there is still not a structural fix for this. Let's hope this +1 can make the difference. Well i didn't wait for it for 7 years ;-) The solutions have been available by the addition of vMix scripting (before htat it was solved using external scripting) ;-) using a Script makes it even more flexible ;-) The solution principle has been posted in the forum somewhere : lookup last recording and rename it to your liking ;-) Couldn't find it when searching for recording, name, rename etc. Any chance of pointing me in the right direction?
Originally Posted by: Vegazz  Originally Posted by: doggy  Originally Posted by: Vegazz  +1, weird enough after all these years there is still not a structural fix for this. Let's hope this +1 can make the difference. Well i didn't wait for it for 7 years ;-) The solutions have been available by the addition of vMix scripting (before htat it was solved using external scripting) ;-) using a Script makes it even more flexible ;-) The solution principle has been posted in the forum somewhere : lookup last recording and rename it to your liking ;-) Couldn't find it when searching for recording, name, rename etc. Any chance of pointing me in the right direction? https://forums.vmix.com/...rded-clip-name#post76144https://forums.vmix.com/...ecord-Filename#post91423
