NDI
a little confused
Joined: 12/27/2012(UTC) Posts: 5,521  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Due to a little issue with the latest NDI connect I like to be sure regarding something and confirm:
When a camera input is opened in vMix on a remote unit one can not only get the vMix output on the network but also the camera itself so vMix is creating a ndi source of every camera input? ( connect on remote computer can then see this camera as if it was a local camera )
Hi Doggy
if you set this in vMix settings yes
vMix can provide the network with NDI streams of the output, external2 and all cameras/calls/audio inputs and also audio outputs
and the use of SetOutputExternal2 command allows you to send and switch any input to NDI
Duh, thanks for reminding DWAM :-)
DWAM wrote:and the use of SetOutputExternal2 command allows you to send and switch any input to NDI But not titles PPTs etc right?
NDI
a little confused
