#1 Posted : Friday, February 24, 2017 5:56:04 AM(UTC)
Due to a little issue with the latest NDI connect I like to be sure regarding something and confirm:
When a camera input is opened in vMix on a remote unit one can not only get the vMix output on the network but also the camera itself so vMix is creating a ndi source of every camera input? ( connect on remote computer can then see this camera as if it was a local camera )
#2 Posted : Friday, February 24, 2017 6:39:54 AM(UTC)
Hi Doggy
if you set this in vMix settings yes
vMix can provide the network with NDI streams of the output, external2 and all cameras/calls/audio inputs and also audio outputs
#3 Posted : Friday, February 24, 2017 6:53:42 AM(UTC)
and the use of SetOutputExternal2 command allows you to send and switch any input to NDI
#4 Posted : Friday, February 24, 2017 7:13:59 AM(UTC)
Duh, thanks for reminding DWAM :-)
kjones9999
#5 Posted : Friday, February 24, 2017 9:14:50 PM(UTC)
kjones9999
But not titles PPTs etc right?
#6 Posted : Saturday, February 25, 2017 3:13:56 AM(UTC)
"any input" means titles, PPT or really ANY input! ;o)
You can check this post where I explain how to "create" an independent switcher for External2 output
https://forums.vmix.com/...ts&m=34998#post34998
