AMD memory error on startup
Advanced Micro Devices, Inc. driver update for AMD Radeon (TM) R9 390 Series.
this update from microsoft is the problem. i have stop microsoft update. for go around the problem.
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 152 times Was thanked: 76 time(s) in 57 post(s)
Then is this problem whit AMD grafik card gona be fixed i fink it was a little problem maybe i have to buy a nvidia card just for running Vmix. Sad user.
Rank: Staff
Groups: Registered, Administrators Joined: 12/13/2012(UTC) Posts: 242 Location: Gold Coast, Australia
Thanks: 7 times Was thanked: 159 time(s) in 72 post(s)
It appears the latest drivers may have fixed the issue. I've been testing 16.10.3 and 16.11.5 with no more lockups. Can anyone else confirm?
vmixsupport wrote:It appears the latest drivers may have fixed the issue. I've been testing 16.10.3 and 16.11.5 with no more lockups. Can anyone else confirm? What version of vMix did you test on? I will test ASAP
 1 user thanked AndrewZarian for this useful post.
Just tried it and it still locked up. what process did you use to install the new driver. Did you delete the previous version before installing?
Joined: 1/13/2010(UTC) Posts: 5,325  Location: Gold Coast, Australia Was thanked: 4728 time(s) in 1620 post(s)
Unfortunately it was a false alarm, we will need to chase this up with AMD again. Sorry about that.
With VMix being a secondary activity for the computer that I intend to use I have just stopped using VMix until a fix has been presented. I am really hoping that something can be done about this since VMix is the only application with this issue, as stated above in the thread. Just wanted to add to the "me toos" in hopes that we can get a fix.
A workaround has been added to the latest 18 update (18.0.0.58). It's not a fix as such, but it should get vMix up and running until AMD releases a driver fix.
The down side of this workaround is slightly reduced quality on the Fullscreen outputs but this has no impact on the quality of the stream or recording.
Martin vMix
admin wrote:A workaround has been added to the latest 18 update (18.0.0.58). It's not a fix as such, but it should get vMix up and running until AMD releases a driver fix.
Martin vMix Thank you Martin for the update please keep us posted :)
AndrewZarian wrote:admin wrote:A workaround has been added to the latest 18 update (18.0.0.58). It's not a fix as such, but it should get vMix up and running until AMD releases a driver fix.
Martin vMix Thank you Martin for the update please keep us posted :) Any updates :)
Rille wrote:Advanced Micro Devices, Inc. driver update for AMD Radeon (TM) R9 390 Series.
yes i confirm this is a issue, use the older driver, until AMD correct the latest driver
Hi everyone. Wanted to see if there was an update to this
thanks!
AMD still haven't fixed the bug, however the latest vMix updates all work fine with AMD now, albeit at slightly lower quality, due to a workaround we added.
