JohanSpijker
#1 Posted : Sunday, February 5, 2017 7:21:08 AM(UTC)
JohanSpijker
Hi there,
Can somebody tell me what is the filename and correct path of the xml file (under api)
I am now browsing to: http://192.168.1.46:8088/api
but the xml opens in my browser, do you know the correct filename and path of the xml file ?
Thanks a lot!
#2 Posted : Sunday, February 5, 2017 7:37:47 AM(UTC)
Hi Johan
I quite don't understand what you expect here. This is the normal behaviour. XML urls starting with http:// are supposed to open in your web browser, aren't they?
JohanSpijker
#3 Posted : Sunday, February 5, 2017 9:23:49 AM(UTC)
JohanSpijker
I want to use the ***.xml file, import it in a 3 party touchpaneel, so I can read out the status, etc
#4 Posted : Sunday, February 5, 2017 9:49:12 AM(UTC)
I still don't understand what you expect...
You've got the correct url for reading vMix API status in XML format in a "web browser" (as explicitely indicated by the use of the http protocol)
You can save this into a "static" file from your web browser if you want, but it makes no sense as, by definition, vMix status changes all the time depending on each and every actions that are done in vMix.
AFAIK there is no other way to read vMix API status.
JohanSpijker
#5 Posted : Sunday, February 5, 2017 10:59:41 AM(UTC)
JohanSpijker
Is anybody know what the "21207c48-ec14-4b0b-9671-418213cb23e6" means in the xml.
Is that random ?
<vmix>
<version>18.0.0.59</version>
<inputs>
<input key="21207c48-ec14-4b0b-9671-418213cb23e6" number="1" type="Video" title="wolken alleen" state="Paused" position="69169" duration="597612" loop="False" muted="True" volume="100" balance="0" solo="False" audiobusses="M,A,B" meterF1="0" meterF2="0">
wolken alleen
<position zoomX="1.525" zoomY="1.525"/>
</input>
</inputs>
</vmix>
#6 Posted : Sunday, February 5, 2017 11:11:01 AM(UTC)
It is a unique identifyer for inputs. It's called "GUID". It is a better way to call/select inputs as opposed to using the input number (1 in your example) which is subject to change when you add or remove inputs in your vMix project.
Check the documentation for more details:
http://www.vmix.com/help18/DeveloperAPI.html
JohanSpijker
#7 Posted : Sunday, February 5, 2017 7:15:13 PM(UTC)
JohanSpijker
But this GUID changes all the time, so it is not usable to do status request for that input ?
I am building een ceremony (funerals) app to control some inputs (photoshow, video, PowerPoint, etc)
The technician put the content in the correct (fixed)inputs in the VMIX pc.
( input1: photoshow ; input two: video ; input three: another photoshow ;.....)
The person who is in front of the public only have to push a few buttons on the tablet, that activate the quick-play of the correct inputs in the v-mix.
Controlling is not the problem, but I want to show also info on the tablet.
That is the reason why I want to read the XML.
below is a piece of javascript code i use that works fine for the "version", "recording state",....but not for the inputs :(
function infoVmix() {
CF.request("http://192.168.1.46:8088/api", parseData3);
function parseData3(status,headers,body) {
if (status == 200) {
var parser = new DOMParser();
var doc = parser.parseFromString(body, "text/xml");
var versionElement = doc.getElementsByTagName("version")[0];
CF.log ("version =" + versionElement.textContent);
CF.setJoin("s2055", versionElement.textContent);
#8 Posted : Monday, February 6, 2017 3:49:13 AM(UTC)
GUIDs won't change if you save your project as a vMix preset
Similar Topics
Converting string from API.XML to integer (General Discussion)
by svetotehnik 2/20/2021 5:42:36 PM(UTC)
Convert Replay.XML InPoint To Time (Instant Replay)
by dror 2/14/2021 3:03:39 AM(UTC)
Script error "replay.xml is being used by another process." (Instant Replay)
by Ario 3/9/2020 8:47:31 AM(UTC)
Audio Fade Script: API.XML Audio Numbers in a different scale to Volume Shortcut Scale (3rd Party Software and Development)
by aircooled76@gmail.com 9/9/2018 12:31:26 PM(UTC)
Replay.xml (Instant Replay)
Belarus MFilgueiras 9/6/2018 9:55:09 AM(UTC)
Virtualset config.xml resets / don't save (General Discussion)
by iluppiHD 4/5/2017 3:40:55 AM(UTC)
