Instant Replay
Convert Replay.XML InPoint To Time
in the Replay.xml I have an IN point like this 52387200000 and in vmix the display is 18:57:31.44 what is the number format? milliseconds? seconds?
how can i covert it ?
you have to divide it with 10000000 than you have seconds (you can check it with in- and outpoint) but it starts with Zero or something else at the beginning of the captured replay
<outPoint>9223372036854775807</outPoint> means no outpoint is set
you also have to look at the <videoStartTime> to get the correct time
<segment> <timestamp>2021-02-13T18:36:16.8730199+01:00</timestamp> <videoStartTime>167389400000</videoStartTime>
 1 user thanked xaver for this useful post.
thank you for the big help!
Instant Replay
