dror
#1 Posted : Sunday, February 14, 2021 3:03:39 AM(UTC)
dror
Israel
in the Replay.xml
I have an IN point like this 52387200000
and in vmix the display is 18:57:31.44
what is the number format? milliseconds? seconds?
how can i covert it ?
xaver
#2 Posted : Sunday, February 14, 2021 3:43:07 AM(UTC)
xaver
you have to divide it with 10000000 than you have seconds (you can check it with in- and outpoint)
but it starts with Zero or something else at the beginning of the captured replay
<outPoint>9223372036854775807</outPoint>
means no outpoint is set
you also have to look at the <videoStartTime> to get the correct time
<segment>
<timestamp>2021-02-13T18:36:16.8730199+01:00</timestamp>
<videoStartTime>167389400000</videoStartTime>
thanks 1 user thanked xaver for this useful post.
msanthababu on 3/28/2023(UTC)
dror
#3 Posted : Sunday, February 14, 2021 5:35:54 AM(UTC)
dror
Israel
thank you for the big help!
Guest (5)
